[Mapserver-users] Use php/mapscript init the mapobj
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Mon Jun 7 03:12:15 EDT 2004
Liangxu Wang schrieb:
> Hi,
> Is there a way to display the vector and raster data using by php/mapscript,but not define in the map file?
> I notice that the MapObj Class Constructor use a initial map file. So,if I can do a null constructor,and then init the mapobj value by my php/mapscript ?
> Thanks.
> wlx
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Hi.
You can use mapscript to generate maps without having a mapfile I think.
I don't use that but I use some kind of template mapfile where I only
included some Parameters I often use and then add new layers, classes,
styles ... .
Remember to use ms_new ... Obj(next higher object) for example
ms_newLayerObj(mapobj).
Then you can use save and load method from the mapobject to save/load
your new map. With this you don't have to do much if you call the script
a second time.
Regards,
Norbert
