[SPAM] - Re: [Mapserver-users] Virtual Spatial Data from SQL Server - Email found in subject
IMD Listuser
imd_listuser at comcast.net
Mon Jun 7 07:33:19 EDT 2004
Thanks Jenu,
Unfortunately your suggestions did not seem to make a difference.
I am thinking that the problem is with permissions on IIS6, since it its
locked down by default. Im not sure that it will allow ODBC connections
to occur unless I explicitly allow them. So, I need to figure out how to
allow them.
Thanks Again
Charlie
-----Original Message-----
Sent: Saturday, June 05, 2004 11:05 AM
To: IMD Listuser
Cc: Mapserver-users at lists.gis.umn.edu
Subject: [SPAM] - Re: [Mapserver-users] Virtual Spatial Data from SQL
Hi charlie
did u say that u are getting any error or u just dont see the points on
the map,
if u see the map but not a point then try adding a dummy symbol layer in
the mapfile....i was facing the same problem...this helped...
also make sure u have the sign in the map right
for the western hemispehere the longitues are negative and northern
hemisphere the latitudes are positive
write back if u still facing the problem
cheers
jenu
_________________________________________________________________
Getting married? Find great tips, tools and the latest trends at MSN
Life Events. http://lifeevents.msn.com/category.aspx?cid=married
