[Mapserver-users] mscalculate()
AARON KONING
aaronkoning at shaw.ca
Mon Jun 7 11:42:32 EDT 2004
I guess I meant you should echo (with the print_r() function) the values in the extent_to_set array in order to confirm that they are indeed floating point numbers and that they form a valid bounding box. Hopefully it will tell you if your arguments are the problem or if you need to look else where.
Aaron
----- Original Message -----
Date: Monday, June 7, 2004 4:52 am
Subject: [Mapserver-users] mscalculate()
> Aaron,
> Thanks for your reply which is beggining to open me up for more
> exploration.
> Seems like i dont understand what you mean floating point numbers
> at appropriate sizes. Hence unable to progress. Could you simplify
> your explaination. Sorry i'm only a beginner in the art of web
> mapping. WHERE DO I BEGIN?
> I would echo out the $extent_to_set[0]ie: floating point numbers
> at
> appropriate sizes) prior to $map->setextent.
> eg:
> print_r($extent_to_set);
> die();
> Aaron
> Do you Yahoo!?
> Friends. Fun. Try the all-new Yahoo! Messenger
