[Mapserver-users] More than 100 layers - Do I really need to
recompile mapserver? {Scanned} {Scanned}
Siki Zoltan
siki at agt.bme.hu
Mon Jun 7 15:14:18 EDT 2004
Recently I had the same problem. First I recompile mapserver after
changing a header file. At that time 255 was the default limit for
layer count.
Later a learnt to use tileindexed layer, which helped me to reduce the
number of layers below the limit. I had a lots of orthophotos.
I hope this helps you
Bye
Zoltan
On Mon, 7 Jun 2004, Trent Burton wrote:
> If I have more than 100 layers, do I really need to recompile Mapserver,
> setting the MS_MAXLAYERS variable of the map.h header file?
> Does anyone know if 400-500 layers is an issue for Mapserver?
> Is there some site out there that has different versions of Mapserver
> binaries for Windows with different options and libraries? I really do
> not want to have to get into compiling mapserver from the source.
> Thanks,
> Trent Burton
