[Mapserver-users] about extent
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Tue Jun 8 02:53:46 EDT 2004
boli schrieb:
> Hello EveryBody:
> I am really confused now. I have downloaded and installed the tutorial package and that runs well on my conmputer. But when I checked the map file of "example1-1.map", the extent item there is "EXTENT 201621.496941 -294488.285333 1425518.020722 498254.51151". While I got the extent from "states_ugl.shp" with "shpinfo", the extent is "-97.23 41.61 -82.12 49.38". What is wrong?
> boli
> boli611 at hotmail.com
> 2004-06-08
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Hi.
This is good like it is. There is nothing wrong. You have to look at the
projections in:
http://mapserver.gis.umn.edu/doc40/mapfile-reference.html
There are two points to have a projection: one for the whole map and one
for each layer. This gives you the handle to use different data and
provide it in one coordinate system. Without it all your data must have
the same projection or you will not see the data together.
When I look at your extents it seems that the map is in some kind of
projection and your data/layer is in geographical coordinates.
Regards,
Norbert
