[Mapserver-users] GEOS intersection problem
Mark Cave-Ayland
m.cave-ayland at webbased.co.uk
Wed Jun 9 04:04:12 EDT 2004
Hi Zhigang,
It would seem that this is not a mapserver issue but most likely a
PostGIS/GEOS issue. I would suggest reposting this to the geos-devel
mailing list (see http://geos.refractions.net) and the postgis-users
mailing list (see http://postgis.refractions.net).
Kind regards,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: mapserver-users-admin at lists.gis.umn.edu
> [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> songzh at cs.orst.edu
> Sent: 08 June 2004 05:40
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] GEOS intersection problem
> When I performed the intersection between a MULTILINESTRING
> and a POLYGON, the generated MULTILINESTRING shot off a line
> which went outside the images
> extents. The details are as the following:
> 1) The version of GEOS is downloaded from:
> [2003//11/06]geos-1.0.0.tar.gz on http://geos.refraction.net
> It's the latest version I can find.
> 2) The intersection geometry objects are as the following.
> geom_base (it has three single lines with a common jointed point):
> "SRID=6010;MULTILINESTRING((602797 1045929,602897
> 1045629),(602897 1045629,602997 1045929),(602897
> 1045629,602897 1045529,602897 1045599,602897 1045439,602897 1045429))"
> geom_py (a rectangle):
> "SRID=6010;POLYGON((602797 1045829,602997 1045829,602997
> 1045529,602797 1045529,602797 1045829))"
> 3) After the SQL statement "select intersection(geom_base,
> geom_py) from intersect_test" was issued, the intersected
> geometry object was:
> geom_intersect ( a multilinestring):
> "SRID=6010;MULTILINESTRING((602830.333333333 1045829,602897
> 1045629),(602897 1045629,602963.666666667 1045829),(602897
> 1045629,602897 1045599),(602897 1045599,2.30261934254173e-269
> 1.20137436645991e-301))"
> We can see that one of the generated multiline string has a
> point " 2.30261934254173e-269 1.20137436645991e-301 " which
> is actually (0,0). It shows that one of the result line
> string links to the point (0, 0), which caused the line going
> out the image range. I want to know if anybody has any idea
> about this. How to avoid it?
> Thanks a lot!
> Yours,
> Zhigang Song
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
