[Mapserver-users] crash using srs parameter in getmap request
craig.gould at bt.com
Thu Jun 10 07:32:49 EDT 2004
John,
I and a few others have found the same problem.
The way round it is to create a web page that is called instead of the
opengis mapserver. This page forwards the request to the mapserver but
strips out the SRS paramater. If the map server is using the projection
you want returned by default, then everything ends up OK.
BTW this only happens with certain projection types.
Regards,
Craig.
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of John
Pulles
Sent: 10 June 2004 10:28
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] crash using srs parameter in getmap request
Hi List
Using a map file with projection settings as shown below, I get a crash
of mapserver when doing an opengis getmap request with &srs=epsg:28992.
With an absent srs parameter or with &srs=epsg:4326 a correct map is
returned. Does anyone have an idea what could be wrong?
BTW: I am using MapServer version 4.2-beta2 on W2K, with the PROJ_LIB
environment variable set to the directory containing the epsg file.
Regards,
John Pulles.
MAP
NAME "Demo"
PROJECTION
# RD
"init=EPSG:28992"
END
EXTENT 10000 305000 280000 619000
SHAPEPATH "c:\kaarten"
UNITS meters
WEB
METADATA
"wms_title" "Demo"
"wms_srs" "EPSG:4326 EPSG:28992"
END
END
LAYER
NAME provincies
DATA "provincies"
STATUS ON
METADATA
"wms_title" "Provincies"
END
TYPE POLYGON
CLASS
COLOR 212 212 212
OUTLINECOLOR 0 0 0
END
PROJECTION
# RD
"init=EPSG:28992"
END
END
END
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
