[Mapserver-users] crash using srs parameter in getmap request
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Thu Jun 10 09:19:05 EDT 2004
Actually, one of my colleagues had this issue a few days ago. Upgrading
to 4.2 eliminated the problem. Maybe this will work for you?
..Tom
> -----Original Message-----
> From: craig.gould at bt.com [mailto:craig.gould at bt.com]
> Sent: Thursday, June 10, 2004 9:17 AM
> To: Kralidis,Tom [Burlington]; john.pulles at geodan.nl;
> mapserver-users at lists.gis.umn.edu
> Subject: RE: [Mapserver-users] crash using srs parameter in
> getmap request
> Tom,
> If John's crash is anything like the crash I experienced then
> it is the actual mapserv process on the machine that crashes
> with a null pointer exception somewhere.
> This crash only happens with certain types of projections. I
> was using British National Grid (BNG). The native projection
> of the WMS server was BNG, and the native projection of the
> WMS client was BNG. However if I include the SRS parameter
> then the map server process on the WMS server crashed
> (however not if you used a browser and did a standard
> request). If I took out the SRS parameter via a redirecting
> page the process did not crash.
> Upper and lower case made no difference for me. The
> application still crashed.
> BTW, when I found this problem I posted it on this list, but
> got no answer back. Since then at least two other people have
> posted similar problems. Each time I've let them know how I
> got round the problem. Unfortunately I can't get seem to get
> map server to compile on my win machine so I can't look into
> where this may be happening.
> Craig.
> From: Kralidis,Tom [Burlington] [mailto:Tom.Kralidis at ec.gc.ca]
> Sent: 10 June 2004 14:04
> To: Gould,CR,Craig,XGH6A C; john.pulles at geodan.nl;
> getmap request
> Comments:
> - What do you mean by MapServer crashing? Are you getting a
> 500 error? Are you getting an OGC Service Exception Report
> XML document?
> - What is the *native* projection of the data? This is what
> should be declared in the PROJECTION block foreach layer
> - try your "wms_srs" declaration with lowercase (i.e.
> "init=epsg:28992")
> - trying a WMS GetMap request without the SRS keyword is an
> invalid request, and should throw an exception
> - WMS is not the problem. A WMS shall support all SRS
> projections it advertises in Capabilities
> ..Tom
> Tom Kralidis
> Systems Scientist
> Environment Canada
> Tel: +01-905-336-4409
> http://www.ec.gc.ca/
> > From: mapserver-users-admin at lists.gis.umn.edu
> > [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
> > Sent: Thursday, June 10, 2004 7:33 AM
> > To: john.pulles at geodan.nl; mapserver-users at lists.gis.umn.edu
> > getmap request
> > John,
> > I and a few others have found the same problem.
> > The way round it is to create a web page that is called
> instead of the
> > opengis mapserver. This page forwards the request to the
> mapserver but
> > strips out the SRS paramater. If the map server is using the
> > projection you want returned by default, then everything
> ends up OK.
> > BTW this only happens with certain projection types. Regards, Craig.
> > [mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of John
> > Pulles
> > Sent: 10 June 2004 10:28
> > To: mapserver-users at lists.gis.umn.edu
> > Subject: [Mapserver-users] crash using srs parameter in
> getmap request
> > Hi List
> > Using a map file with projection settings as shown below, I get a
> > crash of mapserver when doing an opengis getmap request with
> > &srs=epsg:28992. With an absent srs parameter or with
> &srs=epsg:4326 a
> > correct map is returned. Does anyone have an idea what
> could be wrong?
> > BTW: I am using MapServer version 4.2-beta2 on W2K, with
> the PROJ_LIB
> > environment variable set to the directory containing the epsg file.
> > Regards,
> > John Pulles.
> > MAP
> > NAME "Demo"
> > PROJECTION
> > # RD
> > "init=EPSG:28992"
> > END
> > EXTENT 10000 305000 280000 619000
> > SHAPEPATH "c:\kaarten"
> > UNITS meters
> > WEB
> > METADATA
> > "wms_title" "Demo"
> > "wms_srs" "EPSG:4326 EPSG:28992"
> > END
> > END
> > LAYER
> > NAME provincies
> > DATA "provincies"
> > STATUS ON
> > METADATA
> > "wms_title" "Provincies"
> > END
> > TYPE POLYGON
> > CLASS
> > COLOR 212 212 212
> > OUTLINECOLOR 0 0 0
> > END
> > PROJECTION
> > # RD
> > "init=EPSG:28992"
> > END
> > END
> > END
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
