[Mapserver-users] crash using srs parameter in getmap request
Ed McNierney ed at topozone.com
Thu Jun 10 09:40:02 EDT 2004
Folks -
What version of MapServer are you running when you get this crash?  My
memory is being fuzzy right now, but there was a bug quite a while ago
that had something to do with a buffer/pointer problem with SRS
parameters (I think).  I ran into it and Daniel fixed it - but it was
rather a long time ago.  If you're using an old version of MapServer,
try something newer.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
craig.gould at bt.com
Sent: Thursday, June 10, 2004 9:17 AM
To: Tom.Kralidis at ec.gc.ca; john.pulles at geodan.nl;
mapserver-users at lists.gis.umn.edu
Subject: RE: [Mapserver-users] crash using srs parameter in getmap
request
Tom,
If John's crash is anything like the crash I experienced then it is the
actual mapserv process on the machine that crashes with a null pointer
exception somewhere.
This crash only happens with certain types of projections. I was using
British National Grid (BNG). The native projection of the WMS server was
BNG, and the native projection of the WMS client was BNG. However if I
include the SRS parameter then the map server process on the WMS server
crashed (however not if you used a browser and did a standard request).
If I took out the SRS parameter via a redirecting page the process did
not crash.
Upper and lower case made no difference for me. The application still
crashed.
BTW, when I found this problem I posted it on this list, but got no
answer back. Since then at least two other people have posted similar
problems. Each time I've let them know how I got round the problem.
Unfortunately I can't get seem to get map server to compile on my win
machine so I can't look into where this may be happening.
Craig.
From: Kralidis,Tom [Burlington] [mailto:Tom.Kralidis at ec.gc.ca]
Sent: 10 June 2004 14:04
To: Gould,CR,Craig,XGH6A C; john.pulles at geodan.nl;
request
Comments:
- What do you mean by MapServer crashing?  Are you getting a 500 error?
Are you getting an OGC Service Exception Report XML document?
- What is the *native* projection of the data?  This is what should be
declared in the PROJECTION block foreach layer
- try your "wms_srs" declaration with lowercase (i.e. "init=epsg:28992")
- trying a WMS GetMap request without the SRS keyword is an invalid
request, and should throw an exception
- WMS is not the problem.  A WMS shall support all SRS projections it
advertises in Capabilities
..Tom
Tom Kralidis
Systems Scientist
Environment Canada
Tel: +01-905-336-4409
http://www.ec.gc.ca/
> From: mapserver-users-admin at lists.gis.umn.edu
> Sent: Thursday, June 10, 2004 7:33 AM
> To: john.pulles at geodan.nl; mapserver-users at lists.gis.umn.edu
> getmap request
> John,
> I and a few others have found the same problem.
> The way round it is to create a web page that is called
> instead of the opengis mapserver. This page forwards the
> request to the mapserver but strips out the SRS paramater. If
> the map server is using the projection you want returned by
> default, then everything ends up OK. BTW this only happens
> with certain projection types. Regards, Craig.
> John Pulles
> Sent: 10 June 2004 10:28
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] crash using srs parameter in getmap request
> Hi List
> Using a map file with projection settings as shown below, I
> get a crash of mapserver when doing an opengis getmap request
> with &srs=epsg:28992. With an absent srs parameter or with
> &srs=epsg:4326 a correct map is returned. Does anyone have an
> idea what could be wrong?
> BTW: I am using MapServer version 4.2-beta2 on W2K, with the
> PROJ_LIB environment variable set to the directory containing
> the epsg file.
> Regards,
> John Pulles.
> MAP
>     NAME "Demo"
>     PROJECTION
>         # RD
>         "init=EPSG:28992"
>     END
>     EXTENT 10000 305000 280000 619000
>     SHAPEPATH "c:\kaarten"
>     UNITS meters
>     WEB
>         METADATA
>             "wms_title"         "Demo"
>             "wms_srs"	        "EPSG:4326 EPSG:28992"
>         END
>     END
>     LAYER
>         NAME provincies
>         DATA "provincies"
>         STATUS ON
>         METADATA
>             "wms_title"         "Provincies"
>         END
>         TYPE POLYGON
>         CLASS
>             COLOR 212 212 212
>             OUTLINECOLOR 0 0 0
>         END
>         PROJECTION
>             # RD
>             "init=EPSG:28992"
>         END
>     END
> END
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
