[Mapserver-users] crash using srs parameter in getmap request
John Pulles
john.pulles at geodan.nl
Thu Jun 10 09:46:32 EDT 2004
Kralidis,Tom [Burlington] wrote:
>Comments:
>- What do you mean by MapServer crashing? Are you getting a 500 error?
>Are you getting an OGC Service Exception Report XML document?
My browser shows:"
CGI Error
The specified CGI application misbehaved by not returning a complete set
of HTTP headers. The headers it did return are:"
and a message box with title "mapserv.exe - Application Error" shows
"The instruction at "0x101c7e24" referenced memory at "0xcccc1033". The
memory could not be "read".
Alas, no service exception report.
>- What is the *native* projection of the data? This is what should be
>declared in the PROJECTION block foreach layer
The native projection is the same as epsg:28992 which is declared in the
PROJECTION block for that layer and for the map. (see the end of this
e-mail)
>- try your "wms_srs" declaration with lowercase (i.e. "init=epsg:28992")
I did try this, but is doesn't make a difference.
>- trying a WMS GetMap request without the SRS keyword is an invalid
>request, and should throw an exception
I read the same in the wms specification. Should a bug report be filed
for this? Although there are already 5 entries when searching for srs
(but none for this problem).
John.
>- WMS is not the problem. A WMS shall support all SRS projections it
>advertises in Capabilities
>..Tom
>Tom Kralidis
>Systems Scientist
>Environment Canada
>Tel: +01-905-336-4409
>http://www.ec.gc.ca/
>>-----Original Message-----
>>From: mapserver-users-admin at lists.gis.umn.edu
>>[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of
>>craig.gould at bt.com
>>Sent: Thursday, June 10, 2004 7:33 AM
>>To: john.pulles at geodan.nl; mapserver-users at lists.gis.umn.edu
>>Subject: RE: [Mapserver-users] crash using srs parameter in
>>getmap request
>>John,
>>I and a few others have found the same problem.
>>The way round it is to create a web page that is called
>>instead of the opengis mapserver. This page forwards the
>>request to the mapserver but strips out the SRS paramater. If
>>the map server is using the projection you want returned by
>>default, then everything ends up OK. BTW this only happens
>>with certain projection types. Regards, Craig.
>>John Pulles
>>Sent: 10 June 2004 10:28
>>To: mapserver-users at lists.gis.umn.edu
>>Subject: [Mapserver-users] crash using srs parameter in getmap request
>>Hi List
>>Using a map file with projection settings as shown below, I
>>get a crash of mapserver when doing an opengis getmap request
>>with &srs=epsg:28992. With an absent srs parameter or with
>>&srs=epsg:4326 a correct map is returned. Does anyone have an
>>idea what could be wrong?
>>BTW: I am using MapServer version 4.2-beta2 on W2K, with the
>>PROJ_LIB environment variable set to the directory containing
>>the epsg file.
>>Regards,
>>John Pulles.
>>MAP
>> NAME "Demo"
>> PROJECTION
>> # RD
>> "init=EPSG:28992"
>> END
>> EXTENT 10000 305000 280000 619000
>> SHAPEPATH "c:\kaarten"
>> UNITS meters
>> WEB
>> METADATA
>> "wms_title" "Demo"
>> "wms_srs" "EPSG:4326 EPSG:28992"
>> END
>> END
>> LAYER
>> NAME provincies
>> DATA "provincies"
>> STATUS ON
>> METADATA
>> "wms_title" "Provincies"
>> END
>> TYPE POLYGON
>> CLASS
>> COLOR 212 212 212
>> OUTLINECOLOR 0 0 0
>> END
>> PROJECTION
>> # RD
>> "init=EPSG:28992"
>> END
>> END
>>END
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/maps> erver-users
Geodan IT b.v.
Buitenhaven 27-A
5211 TP 's-Hertogenbosch (NL)
Tel: +31 (0)73 - 692 5151
Fax: +31 (0)73 - 692 5150
Mobiel: +(0)6 - 1234 5678
Postadres / mailing address
President Kennedylaan 1
1079 MB Amsterdam (NL)
E-mail: john.pulles at geodan.nl
Website: http://www.geodan.nl
Disclaimer: http://www.geodan.nl/disclaimer
