[Mapserver-users] Using OS MasterMap with MapServer
Andrew Haigh
andrew at andrewhaigh.net
Fri Jun 11 13:46:11 EDT 2004
--Apple-Mail-1--852894953
Content-Transfer-Encoding: quoted-printable
Content-Type: text/plain;
charset=ISO-8859-1;
delsp=yes;
format=flowed
It all depends what format your MasterMap is in? GML? Shapefile? =20
MapInfo Tab?
Getting MasterMap. to work from a shapefile is easy, however, if your =20=
data is GML then I think you'll need convert it.
You might be able to read it in via OGR/GDAL but I've never tried it =20
(www.remotesensing.org/gdal/), if your using the none topographically =20=
structured version.
If you look on the OS website =20
(http://www.ordnancesurvey.co.uk/oswebsite/products/osmastermap/=20
systems/index.html) this will tell you what software claims to be =20
compatabile.
Not sure if this is helpful or not.
Regards,
Andrew
On 10 Jun 2004, at 13:52, guoloi dou wrote:
> I am new to GIS and am trying to implement a web-based navigation =20
> system to display Ordnance Survey MasterMap data. Below=A0are the =20
> technologies availabe:
> 1.PHP;
> 2.MySQL;
> 3.OS MasterMap
> 4.MapServer
> 5.Apache on Windows XP
> =A0
> Could someone tell me how MasterMap be used by MapServer so that I can =
=20
> extract location information from MapServer and MySQL?
> =A0
> Your help would be appreciated
> =A0
> Best regards,
> Zhengda Lu
Content-Type: text/enriched;
charset=ISO-8859-1
MapInfo Tab?
data is GML then I think you'll need convert it. =20
(<fontfamily><param>Arial</param><color><param>0000,8080,0000</param><x-ta=
d-bigger>www.remotesensing.org/gdal/</x-tad-bigger></color></fontfamily>),=
if your using the none topographically structured version.
(http://www.ordnancesurvey.co.uk/oswebsite/products/osmastermap/systems/in=
dex.html)
this will tell you what software claims to be compatabile.=20
Regards,
Andrew
<excerpt><fontfamily><param>Times New Roman</param><smaller>I am new
to GIS and am trying to implement a web-based navigation system to
display Ordnance Survey MasterMap data. Below=A0are the technologies
availabe:</smaller></fontfamily>
<fontfamily><param>Times New =
Roman</param><smaller>1.PHP;</smaller></fontfamily>
Roman</param><smaller>2.MySQL;</smaller></fontfamily>
<fontfamily><param>Times New Roman</param><smaller>3.OS =
MasterMap</smaller></fontfamily>
Roman</param><smaller>4.MapServer</smaller></fontfamily>
<fontfamily><param>Times New Roman</param><smaller>5.Apache on Windows
XP</smaller></fontfamily>
<smaller>=A0</smaller>
<fontfamily><param>Times New Roman</param><smaller>Could someone tell
me how MasterMap be used by MapServer so that I can extract location
information from MapServer and MySQL?</smaller></fontfamily>
</smaller></fontfamily><smaller>=A0</smaller>
<fontfamily><param>Times New Roman</param><smaller>Your help would be
appreciated</smaller></fontfamily>
<fontfamily><param>Times New Roman</param><smaller>Best =
regards,</smaller></fontfamily>
<fontfamily><param>Times New Roman</param><smaller>Zhengda =
Lu</smaller></fontfamily>
<fontfamily><param>STHeiti</param><color><param>0000,0000,EEEE</param>
</color></fontfamily></excerpt>
--Apple-Mail-1--852894953--
