[Mapserver-users] Building a legend - with class objects in layers
Norbert Thieme
norbert.thieme at ilmenau.baw.de
Tue Jun 15 05:34:25 EDT 2004
Richard Orchard schrieb:
> hi,
> I am using mapserver to display some geology datasets.
> A particular layer has multiple classes in order to show the various
> features (different rock types). The features are color-coded, therefore, i
> need each feature (class) to display in the legend.
> However, when the legend is generated, it just creates one item, based on
> the layer name. it doesn't iterate through the various class objects.
> Is this the way it is supposed to work? Or is there a way to get it to
> create a legend item for each class item within a layer. At present i am
> creating new layer objects for each item i want to display. I have put the
> map file i am using at the bottom of this email.
> Thanks in advance,
> Richard
> ---- mapfile
> MAP
> NAME "Australia - General Information"
> STATUS ON
> EXTENT 109.337 -44.387 158.742 -8.8081
> SIZE 400 300
> SHAPEPATH "D:\webs\www3\gis_data\australia"
> SYMBOLSET "D:\webs\www3\mapserver\etc\symbols.sym"
> FONTSET "D:\webs\www3\mapserver\etc\fonts.txt"
> IMAGETYPE PNG
> IMAGECOLOR 255 255 255
> UNITS DD
> # Start of web interface definition
> WEB
> MINSCALE 2e+06
> MAXSCALE 5e+07
> # On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the
> root
> # of the drive where the .MAP file resides.
> IMAGEPATH "D:/webs/www3/temp/"
> IMAGEURL "/temp/"
> END
> # Start of querymap object
> QUERYMAP
> STATUS OFF
> SIZE -1 -1
> COLOR 255 0 0
> STYLE HILITE
> END
> # Start of legend object
> LEGEND
> STATUS ON
> POSITION LL
> KEYSIZE 18 12
> KEYSPACING 5 5
> TEMPLATE "ttt"
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> OFFSET 0 0
> BUFFER 0
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 0 0 89
> PARTIALS TRUE
> FORCE FALSE
> END
> END
> # Start of scalebar object
> SCALEBAR
> STATUS ON
> COLOR 255 255 255
> OUTLINECOLOR 0 0 0
> BACKGROUNDCOLOR 0 0 0
> UNITS KILOMETERS
> INTERVALS 5
> SIZE 150 5
> STYLE 0
> POSITION LL
> LABEL
> TYPE BITMAP
> SIZE SMALL
> OFFSET 0 0
> BUFFER 0
> MINDISTANCE -1
> MINFEATURESIZE -1
> COLOR 0 0 0
> PARTIALS TRUE
> FORCE FALSE
> END
> END
> # Start of OutputFormat object
> OUTPUTFORMAT
> NAME "png"
> MIMETYPE "image/png"
> DRIVER "GD/PNG"
> EXTENSION "png"
> IMAGEMODE PC256
> TRANSPARENT FALSE
> END
> # Start of layer definitions
> LAYER
> NAME "Roads"
> STATUS ON
> DATA "./roads/roads"
> TYPE LINE
> UNITS METERS
> SIZEUNITS PIXELS
> METADATA
> "Description" "Test"
> END
> CLASS
> NAME "Roads"
> STYLE
> SYMBOL 0
> COLOR 220 0 0
> SIZE 1
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> LAYER
> NAME "Earth Quake Risk 0.05 - 0.10"
> STATUS ON
> DATA "./earthQuakeHazard/eqriskdd"
> TYPE POLYGON
> UNITS KILOMETERS
> SIZEUNITS PIXELS
> METADATA
> "Description" "Earth Quake"
> END
> CLASS
> NAME "RISKVAL2"
> EXPRESSION ('[RISKVAL]' eq '0.05 - 0.10')
> LABEL
> TYPE TRUETYPE
> FONT "fritqat-bold"
> SIZE 10
> POSITION LL
> OFFSET 0 0
> END
> STYLE
> SYMBOL 0
> COLOR 255 150 123
> SIZE 1
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> LAYER
> NAME "Earth Quake Risk < 0.05"
> STATUS ON
> TYPE POLYGON
> UNITS KILOMETERS
> SIZEUNITS PIXELS
> METADATA
> END
> CLASS
> NAME "RISKVAL2"
> EXPRESSION ('[RISKVAL]' eq '< 0.05')
> LABEL
> TYPE TRUETYPE
> FONT "fritqat-bold"
> SIZE 10
> POSITION LL
> OFFSET 0 0
> END
> STYLE
> SYMBOL 0
> COLOR 255 255 181
> SIZE 1
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> LAYER
> NAME "Earth Quake Risk > 0.10"
> STATUS ON
> TYPE POLYGON
> UNITS KILOMETERS
> SIZEUNITS PIXELS
> METADATA
> END
> CLASS
> NAME "RISKVAL2"
> EXPRESSION ('[RISKVAL]' eq '> 0.10')
> LABEL
> TYPE TRUETYPE
> FONT "fritqat-bold"
> SIZE 10
> POSITION LL
> OFFSET 0 0
> END
> STYLE
> SYMBOL 0
> COLOR 247 81 148
> SIZE 1
> MINSIZE 1
> MAXSIZE 100
> END
> END
> END
> # Layer
> END
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the sender immediately and delete the original. Any other use of the email by you is prohibited..
> www.ermapper.com
> www.earthetc.com
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Hi!
The layerobject->numclasses gives you the count of classes. With this
you can loop through and use layer->getClass(int classIndex) to get each
class and draw the legendicons.
Regards,
Norbert
