[Mapserver-users] Unable to access file. set in index.html
COUTUJF at dfo-mpo.gc.ca
Wed Jun 16 21:25:55 EDT 2004
Hi everybody,
Following the meeting in Ottawa last week, I'm trying to set
up a demo mapserver application to show to management what MapServer can do
for us. I'm using apache1.3 on Windows NT4 . I customized the Itasca demo to
fit my data. So here is my problem, let's start with the stuff that works:
If I try
http://serveraddress/mapserv.exe?map=../htdocs/workshop/test.map&mode=map
I get the map I want.
I also specified in the index.html those variables:
<input type="hidden" name="map" value="..\htdocs\workshop\test.map">
<input type="hidden" name="program" value=".\mapserv.exe">
<input type="hidden" name="root" value="..\htdocs\workshop\">
<input type="hidden" name="map_web_imagepath" value="E:\Program
Files\Apache Group\Apache\htdocs\workshop\tmp\">
<input type="hidden" name="map_web_imageurl" value=".\workshop\tmp\">
I can see that the .png files are created by mapServer in the /tmp/
directory, but when I try to use the template, hence the Initialize button
(identical to Itasca one) I get:
Content-type: text/html msReturnPage(): Unable to access file. set in
I did try to get directly to
http://serveraddress/workshop/tmp/filename.png
and I do get the png in the browser so I guess it's no security problem.
please help, thanks!
JF Coutu
Canadian Cost Guard
coutujf at dfo-mpo.gc.ca
