[Mapserver-users] Why Mapserver GML does not validate with XMLSpy
Bart van den Eijnden bartvde at xs4all.nl
Thu Jun 17 14:59:25 EDT 2004
Hi Daniel,
what the XMLSpy people are saying is that using & in a URL to a CGI is
valid.
If I click on the link I do not get the schema back, I get a service
exception report that the version is missing. Or if I use & instead of
& even before the service=WFS name-value pair, I get the "mapserv(): Web
application error. No template provided." error. So mapserv CGI only
interprets name value pairs if they are separated by & instead of &.
Is this something Windows specific perhaps, you are probably on Linux when
clicking the URL in a browser? XMLSpy is on Windows as well ofcourse.
Best regards,
Bart
On Thu, 17 Jun 2004 14:23:53 -0400, Daniel Morissette
<dmorissette at dmsolutions.ca> wrote:
> Bart van den Eijnden wrote:
>> Hi Daniel,
>> the guys at Altova (XMLSpy) seem to have a different opinion on this
>> subject, see:
>> http://www.altova.com/forum/forums/forum.asp?forumid=28&page=1&select=4262#xx4262xx
> Different opinion on what?  They wrote that the ampersand needs to be
> escaped in the instance document, which is exactly in line with what I
> wrote. I also added that the client needs to unescape the string
> *before* calling the server and they suggest that this is what is being
> done:
>> ...so this is the URL:
>> http://www.vz.geodan.nl:1112/cgi-bin/mapserv.exe?map=/ms4w_20/apps/general/map/gemeentes.map&SERVICE=WFS&amp;VERSION=1.0.0&amp;REQUEST=DescribeFeatureType&amp;TYPENAME=Gemeentes
>> ...being sent to the server. This is a perfectly valid construction:
>> http://www.biglist.com/lists/xsl-list/archives/200104/msg01061.html
>> ...that your CGI application or web server seems to be having problems
>> handling correctly.
> ... if I click on the URL above I see a XML schema as expected from a
> DescribeFeatureType response. So what's the problem exactly? What does
> he mean by "having problems handling correctly"?
> Perhaps I missed something obvious at the beginning? Is it that the
> schema that is returned is not valid?
> Daniel
