[Mapserver-users] Ordinal Not found - The ordinal 19 could not be located in the dynamic link library PROJ.dll
Ed McNierney
ed at topozone.com
Tue Jun 22 09:45:30 EDT 2004
This is a multi-part message in MIME format.
------_=_NextPart_001_01C4585F.2F6CDCDC
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
Trent -
=20
I haven't seen that particular problem, but I'm familiar with the error.
Your mapserv.exe was linked against a different version of the PROJ DLL
than the one you are using. It appears the interface changed between
the two versions, and your binary is trying to call an entry point that
doesn't exist in your DLL. You need to use the correct PROJ DLL -
probably the one you had to start with.
=20
I have never heard of a PROJ installation problem causing data not to be
"projected properly". It's far more likely to be a
definition/specification error. If you can give us some details on
what's going wrong, we'll try to help!
=20
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242=20
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Trent
Burton
Sent: Tuesday, June 22, 2004 9:22 AM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Ordinal Not found - The ordinal 19 could not
I had installed Mapserver on Windows using the binaries supplied on the
Mapserver web site. It appeared to me that my data was not being
projected properly so I tried to install PROJ4 as instructed on
MapServer Wiki
http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WindowProjHowTo using the
prebuilt binaries and I get the follwing error pop up on the server when
I make a map request:
=20
=20
mapserv.exe - Ordinal not found
=20
=20
=20
Anyone see this before?
=20
Thanks,
=20
Trent
=20
=20
Content-Type: text/html;
charset="us-ascii"
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD><TITLE>Message</TITLE>
<META http-equiv=3DContent-Type content=3D"text/html; =
charset=3Dus-ascii">
<META content=3D"MSHTML 6.00.2800.1400" name=3DGENERATOR></HEAD>
<BODY>
<DIV dir=3Dltr align=3Dleft><SPAN class=3D499014313-22062004><FONT =
face=3DArial=20
color=3D#0000ff size=3D2>Trent -</FONT></SPAN></DIV>
face=3DArial=20
color=3D#0000ff size=3D2></FONT></SPAN> </DIV>
face=3DArial=20
color=3D#0000ff size=3D2>I haven't seen that particular problem, but I'm =
familiar=20
with the error. Your mapserv.exe was linked against a different =
version of=20
the PROJ DLL than the one you are using. It appears the interface =
changed=20
between the two versions, and your binary is trying to call an entry =
point that=20
doesn't exist in your DLL. You need to use the correct PROJ DLL - =
probably=20
the one you had to start with.</FONT></SPAN></DIV>
face=3DArial=20
face=3DArial=20
color=3D#0000ff size=3D2>I have never heard of a PROJ installation =
problem causing=20
data not to be "projected properly". It's far more likely to be a=20
definition/specification error. If you can give us some details on =
what's=20
going wrong, we'll try to help!</FONT></SPAN></DIV>
face=3DArial=20
<DIV dir=3Dltr align=3Dleft><SPAN =
class=3D499014313-22062004> <FONT=20
face=3DArial color=3D#0000ff size=3D2>- Ed</FONT></SPAN></DIV>
<P><FONT size=3D2>Ed McNierney<BR>President and Chief =
Mapmaker<BR>TopoZone.com /=20
Maps a la carte, Inc.<BR>73 Princeton Street, Suite 305<BR>North =
Chelmsford,=20
MA 01863<BR>ed at topozone.com<BR>(978) 251-4242 =
</FONT></P></SPAN></DIV><BR>
<DIV class=3DOutlookMessageHeader lang=3Den-us dir=3Dltr align=3Dleft>
<HR tabIndex=3D-1>
<FONT face=3DTahoma size=3D2><B>From:</B> =
mapserver-users-admin at lists.gis.umn.edu=20
[mailto:mapserver-users-admin at lists.gis.umn.edu] <B>On Behalf Of =
</B>Trent=20
Burton<BR><B>Sent:</B> Tuesday, June 22, 2004 9:22 AM<BR><B>To:</B>=20
mapserver-users at lists.gis.umn.edu<BR><B>Subject:</B> [Mapserver-users] =
Ordinal=20
Not found - The ordinal 19 could not be located in the dynamic link =
library=20
PROJ.dll<BR></FONT><BR></DIV>
<DIV></DIV>
<DIV><SPAN class=3D722581113-22062004><FONT face=3DArial size=3D2>I had =
installed=20
Mapserver on Windows using the binaries supplied on the Mapserver web=20
site. It appeared to me that my data was not being projected =
properly so I=20
tried to </FONT></SPAN><SPAN class=3D722581113-22062004><FONT =
face=3DArial=20
size=3D2>install PROJ4 as instructed on MapServer Wiki <A=20
href=3D"http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WindowProjHowTo">htt=
p://mapserver.gis.umn.edu/cgi-bin/wiki.pl?WindowProjHowTo</A> using =
the prebuilt binaries and I get the follwing error pop up on the server =
when I=20
make a map request:</FONT></SPAN></DIV>
<DIV><SPAN class=3D722581113-22062004><FONT face=3DArial=20
size=3D2>----------------------------------------------------------------=
---------------------------------------</FONT></SPAN></DIV>
<DIV><SPAN class=3D722581113-22062004><FONT face=3DArial =
size=3D2>mapserv.exe -=20
Ordinal not found</FONT></SPAN></DIV>
<DIV><SPAN class=3D722581113-22062004><FONT face=3DArial size=3D2>The =
ordinal 19 could=20
not be located in the dynamic link library PROJ.dl</FONT></SPAN></DIV>
---------------------------------------</FONT></SPAN></DIV></SPAN></DIV>
<DIV><SPAN class=3D722581113-22062004><FONT face=3DArial size=3D2>Anyone =
see this=20
before?</FONT></SPAN></DIV>
size=3D2>Thanks,</FONT></SPAN></DIV>
size=3D2>Trent</FONT></SPAN></DIV>
size=3D2></FONT></SPAN> </DIV></BODY></HTML>
------_=_NextPart_001_01C4585F.2F6CDCDC--
