[Mapserver-users] free map server/mapping hundreds of addresses on a webpage
David Bitner
bitner at macnoise.com
Tue Jun 22 10:25:27 EDT 2004
It sounds like you have a list of addresses to geocode after which it will
be a static layer?
If this is the case, one thing you could do is geocode all the addresses,
either by hand or by writing scripts to interact with one of the geocoders
mentioned before, to add an x and a y field to your table with the
addresses. You could then either convert that to a shapefile, or use the
display points from a table method that has been discussed on this list
before.
You could then query these points the same as any other geographic layer.
-----Original Message-----
Sent: Monday, June 21, 2004 4:37 PM
To: bitner at macnoise.com
Subject: RE: [Mapserver-users] free map server/mapping hundreds of
Hello
Thanks for your reply. Is there a way to get all of these geocoded
addresses onto a big US map (and regional, state maps) which could have
clickable points?
Thanks
Ed B
>From: "David Bitner" <bitner at macnoise.com>
>To: "Ed Bourque" <edbourque at hotmail.com>,
><mapserver-users at lists.gis.umn.edu>
>Date: Mon, 21 Jun 2004 16:30:43 -0500
>Three TIGER based geocoders are out there right now that I know of:
>The geocoder.us geocoder:
>http://geocoder.us/
>The VegGIS geocoder:
>http://gis.vegcrew.net/
>The google geocoder:
>http://dan.egnor.name/google.html
>David W Bitner
>GIS Specialist
>Metropolitan Airports Comission
>From: mapserver-users-admin at lists.gis.umn.edu
>[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Ed Bourque
>Sent: Monday, June 21, 2004 3:58 PM
>To: mapserver-users at lists.gis.umn.edu
>Subject: [Mapserver-users] free map server/mapping hundreds of addresses
>on a webpage
>Hello
>I have only the following software (ArcView 3.x) and I would like to be
>able
>to geocode addresses and map these on a website. I thouht TIGER line data
>would be the best.... Which data and software would you recommend?
>Any help would be appreciated
>Ed B
>_______________________________________________
>Mapserver-users mailing list
>Mapserver-users at lists.gis.umn.edu
>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
