[Mapserver-users] free map server/mapping hundreds of addresses on a webpage
David Bitner bitner at macnoise.com
Tue Jun 22 10:57:50 EDT 2004
In ArcView 3.x you can use "add event theme" and then "save as shapefile"
In ArcMap you can use "add xy data" and then export the data as a shapefile
I'm not sure of any non-ESRI utilities.
-----Original Message-----
From: Vincent J. Troisi [mailto:vincent.troisi at colorado.edu]
Sent: Tuesday, June 22, 2004 9:51 AM
To: David Bitner
Cc: Mapserver-Users at Lists. Gis. Umn. Edu; Ed Bourque
Subject: Re: [Mapserver-users] free map server/mapping hundreds of
What utility permits one to convert a table in an ascii text file to
a shapefile?
Thanks.
David Bitner wrote:
> It sounds like you have a list of addresses to geocode after which it will
> be a static layer?
> If this is the case, one thing you could do is geocode all the addresses,
> either by hand or by writing scripts to interact with one of the geocoders
> mentioned before, to add an x and a y field to your table with the
> addresses.  You could then either convert that to a shapefile, or use the
> display points from a table method that has been discussed on this list
> before.
> You could then query these points the same as any other geographic layer.
> From: Ed Bourque [mailto:edbourque at hotmail.com]
> Sent: Monday, June 21, 2004 4:37 PM
> To: bitner at macnoise.com
> Subject: RE: [Mapserver-users] free map server/mapping hundreds of
> Hello
> Thanks for your reply.  Is there a way to get all of these geocoded
> addresses onto a big US map (and regional, state maps) which could have
> clickable points?
> Thanks
> Ed B
>>From: "David Bitner" <bitner at macnoise.com>
>>To: "Ed Bourque" <edbourque at hotmail.com>,
>><mapserver-users at lists.gis.umn.edu>
>>Date: Mon, 21 Jun 2004 16:30:43 -0500
>>Three TIGER based geocoders are out there right now that I know of:
>>The geocoder.us geocoder:
>>http://geocoder.us/
>>The VegGIS geocoder:
>>http://gis.vegcrew.net/
>>The google geocoder:
>>http://dan.egnor.name/google.html
>>David W Bitner
>>GIS Specialist
>>Metropolitan Airports Comission
>>From: mapserver-users-admin at lists.gis.umn.edu
>>[mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Ed Bourque
>>Sent: Monday, June 21, 2004 3:58 PM
>>To: mapserver-users at lists.gis.umn.edu
>>Subject: [Mapserver-users] free map server/mapping hundreds of addresses
>>on a webpage
>>Hello
>>I have only the following software (ArcView 3.x) and I would like to be
>>able
>>to geocode addresses and map these on a website. I thouht TIGER line data
>>would be the best.... Which data and software would you recommend?
>>Any help would be appreciated
>>Ed B
>>_______________________________________________
>>Mapserver-users mailing list
>>Mapserver-users at lists.gis.umn.edu
>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
