[Mapserver-users] free map server/mapping hundreds of addresses
on a webpage
Stephen Woodbridge
woodbri at swoodbridge.com
Tue Jun 22 13:34:48 EDT 2004
You can use Geo::ShapeFile and perl. It is pretty simple to do if you
have any experience with Perl.
-Steve
Vincent J. Troisi wrote:
> What utility permits one to convert a table in an ascii text file to
> a shapefile?
> Thanks.
> David Bitner wrote:
>> It sounds like you have a list of addresses to geocode after which it
>> will
>> be a static layer?
>> If this is the case, one thing you could do is geocode all the addresses,
>> either by hand or by writing scripts to interact with one of the
>> geocoders
>> mentioned before, to add an x and a y field to your table with the
>> addresses. You could then either convert that to a shapefile, or use the
>> display points from a table method that has been discussed on this list
>> before.
>> You could then query these points the same as any other geographic layer.
>> -----Original Message-----
>> From: Ed Bourque [mailto:edbourque at hotmail.com]
>> Sent: Monday, June 21, 2004 4:37 PM
>> To: bitner at macnoise.com
>> Subject: RE: [Mapserver-users] free map server/mapping hundreds of
>> addresses on a webpage
>> Hello
>> Thanks for your reply. Is there a way to get all of these geocoded
>> addresses onto a big US map (and regional, state maps) which could have
>> clickable points?
>> Thanks
>> Ed B
>>> From: "David Bitner" <bitner at macnoise.com>
>>> To: "Ed Bourque" <edbourque at hotmail.com>,
>>> <mapserver-users at lists.gis.umn.edu>
>>> Date: Mon, 21 Jun 2004 16:30:43 -0500
>>> Three TIGER based geocoders are out there right now that I know of:
>>> The geocoder.us geocoder:
>>> http://geocoder.us/
>>> The VegGIS geocoder:
>>> http://gis.vegcrew.net/
>>> The google geocoder:
>>> http://dan.egnor.name/google.html
>>> David W Bitner
>>> GIS Specialist
>>> Metropolitan Airports Comission
>>> From: mapserver-users-admin at lists.gis.umn.edu
>>> [mailto:mapserver-users-admin at lists.gis.umn.edu]On Behalf Of Ed Bourque
>>> Sent: Monday, June 21, 2004 3:58 PM
>>> To: mapserver-users at lists.gis.umn.edu
>>> Subject: [Mapserver-users] free map server/mapping hundreds of addresses
>>> on a webpage
>>> Hello
>>> I have only the following software (ArcView 3.x) and I would like to be
>>> able
>>> to geocode addresses and map these on a website. I thouht TIGER line
>>> data
>>> would be the best.... Which data and software would you recommend?
>>> Any help would be appreciated
>>> Ed B
>>> Mapserver-users mailing list
>>> Mapserver-users at lists.gis.umn.edu
>>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
