[Mapserver-users] possible cause of rendering problems
Steve Lime
steve.lime at dnr.state.mn.us
Tue Jun 22 10:56:48 EDT 2004
I would agree with Bart, folks should move to styles. You certainly
don't want to
mix and match old and new syntax...
Steve
>>> <bartvde at xs4all.nl> 6/22/2004 8:36:37 AM >>>
Hi list,
we had some rendering problems in which we would have around 10 classes
in
a LAYER. Not all of the polygon outlines would be drawn.
The problem was caused by using the following CLASS syntax:
CLASS
EXPRESSION /654[23]/
NAME "dok"
COLOR 255 255 255
STYLE
SYMBOL 0
OUTLINECOLOR 255 0 0
SIZE 2
END
END
So the COLOR was outside the STYLE object.
When we moved the COLOR into the STYLE object, everything worked as
expected.
So bottom line: never mingle the old way of doing symbolization with
the
new STYLE way of doing it.
Best regards,
Bart
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
