[Mapserver-users] OGR ovf access problem
COUTUJF at dfo-mpo.gc.ca
Tue Jun 22 13:26:18 EDT 2004
Hello list,
I'm trying to access a distant Oracle database from Mapserver using
the ovf file and an ODBC connection. I tested the ovf file with ogrinfo as
per the WIKI and it worked OK.
When I try to access the layer in mapserver I keep getting the following
error message:
msDrawMap(): Image handling error. Failed to draw layer named 'sipa'.
msOGRFileOpen(): OGR error. Open failed for OGR connection `sipa.ovf'. File
not found or unsupported format.
I did try to follow WIKI tip #1:
1.Enable mod_env
2.add lines like: setenv ORACLE_HOME /path/
3.restart apache
But I don't have Oracle installed on the webserver's machine, only the ODBC
driver.
So I can't figure out what the path should be...
Must I install Oracle?
Thanks,
JF
Jean-Francois Coutu
Canadian Coast Guard
coutujf at dfo-mpo.gc.ca
