[Mapserver-users] Linear Referencing Support
Rafael Lucero
luceror at geoplan.ca
Sun Jun 27 08:40:41 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0017_01C45C22.6DD007D0
Content-Type: text/plain;
charset="Windows-1252"
Content-Transfer-Encoding: quoted-printable
Hello all,
=20
I=92m currently investigating the possibility of using UMN Mapserver =
in a
transportation/asset management environment. While I have briefly =
tested
Mapserver, created some simple sites and read some of the documentation, =
I
have some questions that I hope someone here may be able to answer.
=20
1. Does Mapserver support linear vector data with measure values (x,y,m
or x,y,z,m)? More specifically, I have both Shapefiles and Oracle =
Spatial
tables that have measures =96 can Mapserver display them? =20
2. If Mapserver can display linear features with measure values, can I
perform spatial queries against the data? For example, if I click on a
point along a linear feature, is there a method by which I can query the
measure value that corresponded to the mouse click?
3. Is there currently any support for dynamic segmentation? In other
words, if I have either a point or line event table that is linearly
referenced against a spatial route layer, can Mapserver display these
events?
4. Are there any developments currently underway by Mapserver
developers to build in sophisticated linear referencing support? If =
not, is
this an area that is being looked at for future development?
=20
Finally, has anyone here been successful in using Mapserver for the =
purposes
of displaying linearly referenced data (either through native Mapserver
methods, or in an ad-hoc fashion)? I would be extremely interested in
hearing from anyone who has had any sort of experience (good or bad) in =
this
field.=20
=20
Regards,
=20
Rafael Lucero
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.710 / Virus Database: 466 - Release Date: 23/06/2004
=20
Content-Type: text/html;
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3DWindows-1252">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 11">
<meta name=3DOriginator content=3D"Microsoft Word 11">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C45C22.6D8D5980">
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:ValidateAgainstSchemas/>
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
<w:UseWord2002TableStyleRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
<w:LatentStyles DefLockedState=3D"false" LatentStyleCount=3D"156">
</w:LatentStyles>
</xml><![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
/* List Definitions */
@list l0
{mso-list-id:2081976592;
mso-list-type:hybrid;
mso-list-template-ids:1914888016 269025295 269025305 269025307 =
269025295 269025305 269025307 269025295 269025305 269025307;}
@list l0:level1
{mso-level-tab-stop:36.0pt;
mso-level-number-position:left;
text-indent:-18.0pt;}
ol
{margin-bottom:0cm;}
ul
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
</style>
<![endif]-->
</head>
<body lang=3DEN-CA link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span lang=3DEN-US =
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'>Hello =
all,<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><o:p> </o:p></span=
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'><span
style=3D'mso-spacerun:yes'> </span>I’m currently =
investigating the
possibility of using UMN <span class=3DSpellE>Mapserver</span> in a
transportation/asset management environment.<span
style=3D'mso-spacerun:yes'> </span>While I have briefly tested =
<span
class=3DSpellE>Mapserver</span>, created some simple sites and read some =
of the
documentation, I have some questions that I hope someone here may be =
able to
answer.<o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
<ol style=3D'margin-top:0cm' start=3D1 type=3D1>
<li class=3DMsoNormal style=3D'mso-list:l0 level1 lfo1;tab-stops:list =
36.0pt'><font
style=3D'font-size:10.0pt;font-family:
Arial;mso-ansi-language:EN-US'>Does <span =
support linear vector data with measure values (<span =
class=3DSpellE>x<span
class=3DGramE>,y,m</span></span> or <span =
class=3DSpellE>x,y,z,m</span>)?<span
style=3D'mso-spacerun:yes'> </span>More specifically, I have =
both <span
class=3DSpellE>Shapefiles</span> and Oracle Spatial tables that =
have measures
– can <span class=3DSpellE>Mapserver</span> display =
them?<span
style=3D'mso-spacerun:yes'> =
</span><o:p></o:p></span></font></li>
36.0pt'><font
Arial;mso-ansi-language:EN-US'>If <span =
class=3DSpellE>Mapserver</span> can
display linear features with measure values, can I perform spatial =
queries
against the data?<span style=3D'mso-spacerun:yes'> </span>For =
example,
if I click on a point along a linear feature, is there a method by =
which I
can query the measure value that corresponded to the mouse =
click?<o:p></o:p></span></font></li>
36.0pt'><font
Arial;mso-ansi-language:EN-US'>Is there currently any support for =
dynamic
segmentation?<span style=3D'mso-spacerun:yes'> </span>In =
other words,
if I have either a point or line event table that is linearly =
referenced
against a spatial route layer, can <span =
these events?<o:p></o:p></span></font></li>
36.0pt'><font
Arial;mso-ansi-language:EN-US'>Are there any developments currently =
underway
by <span class=3DSpellE>Mapserver</span> developers to build in =
sophisticated
linear referencing support?<span style=3D'mso-spacerun:yes'> =
</span>If
not, is this an area that is being looked at for future =
development?<o:p></o:p></span></font></li>
</ol>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'>Finally, has anyone =
here been
successful in using <span class=3DSpellE>Mapserver</span> for the =
purposes of displaying
linearly referenced data (either through native <span =
methods, or in an ad-hoc fashion)? <span
style=3D'mso-spacerun:yes'> </span>I would be extremely interested =
in
this
field. <o:p></o:p></span></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'>Regards,<o:p></o:p></sp=
an></font></p>
style=3D'font-size:
></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;mso-ansi-language:EN-US'>Rafael =
Lucero<o:p></o:p></span></font></p>
</div>
</body>
</html>
<BR>
<P><FONT SIZE=3D2>---<BR>
Outgoing mail is certified Virus Free.<BR>
Checked by AVG anti-virus system (http://www.grisoft.com).<BR>
Version: 6.0.710 / Virus Database: 466 - Release Date: 23/06/2004<BR>
</FONT> </P>
------=_NextPart_000_0017_01C45C22.6DD007D0--
