[Mapserver-users] load class: jBox not found
Richard Greenwood
rich at greenwoodmap.com
Tue Jun 29 18:42:04 EDT 2004
Michael Smith wrote:
> Does anyone know what causes this error message. I have jBox installed on
> Win2000 and it was running. Not sure what I did to cause this. I have a
> folder on the C:\inetpub\wwwroot\java\jBox that contains the jbox.class.
> When I run Mapserver everythings seems to be working and images of the maps
> are being put into my tmp folder but only grey area is displayed. Thanks
> for any input.
Check your CODEBASE attribute. It can be a full URL, or (more commonly)
just the path from the root of your server. In your case, it should be:
codebase='/java/jBox'
For example:
<applet codebase='/java/jBox'
code='jBox.class'
archive='jBox.jar'
width=[mapwidth]
height=[mapheight]
name='jBox' MAYSCRIPT>
<param name='image' value='http://[host][img]'>
<param name='drag' value=[DRAG]>
<param name='box' value=[BOX]>
<param name='verbose' value='false'>
<param name='thickness' value='2'>
</applet>
Richard Greenwood
www.greenwoodmap.com
