[Mapserver-users] load class: jBox not found
Michael Smith
msmith at sanangelompo.org
Wed Jun 30 11:06:31 EDT 2004
I changed the path in the codebase to a url like you mentioned and that did
it. Thanks for the help.
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Richard
Greenwood
Sent: Tuesday, June 29, 2004 5:42 PM
To: Michael Smith
Cc: mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] load class: jBox not found
Michael Smith wrote:
> Does anyone know what causes this error message. I have jBox
> installed on Win2000 and it was running. Not sure what I did to cause
> this. I have a folder on the C:\inetpub\wwwroot\java\jBox that contains
the jbox.class.
> When I run Mapserver everythings seems to be working and images of the
> maps are being put into my tmp folder but only grey area is displayed.
> Thanks for any input.
Check your CODEBASE attribute. It can be a full URL, or (more commonly) just
the path from the root of your server. In your case, it should be:
codebase='/java/jBox'
For example:
<applet codebase='/java/jBox'
code='jBox.class'
archive='jBox.jar'
width=[mapwidth]
height=[mapheight]
name='jBox' MAYSCRIPT>
<param name='image' value='http://[host][img]'>
<param name='drag' value=[DRAG]>
<param name='box' value=[BOX]>
<param name='verbose' value='false'>
<param name='thickness' value='2'>
</applet>
Richard Greenwood
www.greenwoodmap.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
