wcs issues on getting data
Pericles S. Nacionales
nacional at CBS.UMN.EDU
Wed Nov 10 18:14:06 EST 2004
Nuno,
Are you running the latest versions of MapServer and GDAL? Did you
compile GDAL with the internal TIFF library or an external one?
-Perry
On Wed, 2004-11-10 at 13:49 -0800, Nuno GIL wrote:
> Hi Pericles,
> Let me just point out the results of your suggestions:
> 1. Yes, by requesting
> http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?map=/ge/data/iceds/alpha/umms/wcs_land3.map&layer=L5&mode=map
> A map is shown
> 2. This image is a 8-bit one. I've included:
> OUTPUTFORMAT
> NAME GEOTIFF_8b
> DRIVER "GDAL/GTiff"
> IMAGEMODE PC256
> END
> With the original GetCoverage request the file is
> still empty
> 3. Already inserted the projection block Frank
> suggested and no good result as well
> This is getting difficult... Thanks for your time and
> help,
> Nuno
> --- "Pericles S. Nacionales" <nacional at CBS.UMN.EDU>
> wrote:
> > On Wed, 2004-11-10 at 10:31 -0800, Nuno GIL wrote:
> > > Dear listers,
> > > I've installed mapserver in order to use its wcs
> > > capabilities.
> > > The GetCapabilities request works fine, the
> > problem is
> > > when I try to use the GetCoverage request.
> > Actually I
> > > don't receive any error message, but the received
> > file
> > > is empty.
> > > I'm querying the server with this request:
> http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?REQUEST=GetCoverage&COVERAGE=l5&SERVICE=WCS&map=/ge/data/iceds/alpha/umms/wcs_land3.map&BBOX=48.5,-21.5,48.7,-21.3&FORMAT=GEOTIFF_RGB&CRS=EPSG:4326&RESX=0.00027778&RESY=0.00027778
> > > Does anyone understands what is going wrong? Any
> > help
> > > would be much appreciated.
> > Nuno,
> > 1. Are you able to see the image when you run a
> > regular MapServer CGI
> > request (i.e.
> http://iceds.ge.ucl.ac.uk/cgi-bin/wcs?map=/ge/data/iceds/alpha/umms/wcs_land3.map&layer=LC5&mode=map)?
> > 2. Is your image 16- or 8-bit? If 8-bit, perhaps
> > you should replace
> > IMAGEMODE INT16 with IMAGEMODE PC256 in OUTPUTFORMAT
> > (also replace the
> > NAME accordingly).
> > 3. What Frank said in another post.
> > Cheers!
> > Perry
> > Pericles S. Nacionales <nacional at cbs.umn.edu>
> __________________________________
> Do you Yahoo!?
> Check out the new Yahoo! Front Page.
> www.yahoo.com
