Postgis nquery returns the same result multiple times
James Martin
martin426 at YAHOO.COM
Wed Nov 17 12:26:47 EST 2004
Hello,
I'm trying to perform a nquery on a postgis layer and am recieving a weird
result. If my DATA = "the_geom from place" the query works fine. However,
when trying:
(SELECT place.the_geom AS the_geom,
place.gid AS gid,
place.name AS name
FROM place
WHERE place.gid=9)
AS foo USING UNIQUE place.gid
USING SRID=-1"
And then bound a point with &imgbox the query returns the correct record,
but returns it 'N' times, where N is the number of rows in the table. The
map itself shows only the one point specified in the WHERE clause. If I
remove the WHERE clause so I can see the other points and bound two of them,
the query returns the first record 2 * N times.
If I do just a query with &imgxy it returns just the one result.
Any help is greatly appreciated!
-James
