Can ArcIMS consume WMS/WFS services?
Judd, Chris Chris.Judd at DEP.STATE.FL.US
Wed Sep 1 09:25:42 EDT 2004
Paul,
You're right.  Here is the response from my ESRI support request.
In answer to your question about whether ArcIMS accepts WMS services as an
input the answer is that it can not.  This is a feature that others have
expressed interest in and the request does have a tracking id of CQ00239065.
The problem is that it does require pretty significant work to the spatial
server and some re-architecting of the spatial server.  Right now work isn't
being undertaken, but it isn't off the radar either.
        I have added your interest for this functionality to the request.
        One approach is to use cascading style sheets in your web application
to layer two WMS output images from different sources on top of one another
with the top one having a transparent background.
        Another approach is that ArcMap Server does serve up data from other
IMS servers (though not WMS, not even with the interoperability extension).
So if the other site you want to serve up is an ArcIMS site you may be able
to consume their service through ArcMap Server.
Bummer.
Chris
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Paul Ramsey
Sent: Tuesday, August 31, 2004 9:10 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Can ArcIMS consume WMS/WFS services?
Probably a question best directed to an ESRI representative.
My best knowledge is that currently the answer is "no", ArcIMS can only
"cascade" against ArcMap web services.
Paul
On Tuesday, August 31, 2004, at 12:56 PM, Judd, Chris wrote:
> List folks,
> We are interested in ArcIMS (we are currently running version 4.0.1)
> consuming a WMS/WFS compliant data service.  We know that ArcIMS can
> serve
> WMS/WFS compliant data services, but can it consume it?
> Thanks for your help,
> Chris Judd
> Florida Department of Environmental Protection
      Paul Ramsey
      Refractions Research
      Email: pramsey at refractions.net
      Phone: (250) 885-0632
