Postgis 0.8.2 doesn't work on Win32
Stefano Bonnin stefano.bonnin at COMAI.TO
Thu Sep 2 08:42:14 EDT 2004
I'have just installed Postgres 8.0.0beta1 and postgis 0.8.2 with the postgis installer found at
http://dcmms.sourceforge.net/postgis_installer.php
After some test (failed) with mapserver, I tryed to execute very simple query like:
CREATE TABLE gtest ( ID int4, NAME varchar(20) );
 SELECT AddGeometryColumn('dbname','gtest','geom',-1,'LINESTRING',2);
INSERT INTO gtest (ID, NAME, GEOM) VALUES (1, 'First Geometry', GeometryFromText('LINESTRING(2 3,4 5,6 5,7 8)', -1));
SELECT id, name, AsText(geom) AS geom FROM gtest;
 id |      name      |            geom
  1 | First Geometry | LINESTRING(2 3,4 5,6 5,7 8)
SELECT id,name FROM GTEST WHERE GEOM  && 'BOX3D(3 4,4 5)'::box3d;
this query crashes the postgres.exe process on "windows XP home SP1"
Can this depend on the OS?
thanks,
RedS
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20040902/4f3b64f6/attachment.html
