Postgis 0.8.2 doesn't work on Win32
Mladen Kotarac
mladen.kotarac at CKFF.SI
Thu Sep 2 09:10:54 EDT 2004
Stefano Bonnin wrote:
> Hi,
> I'have just installed Postgres 8.0.0beta1 and postgis 0.8.2 with the
> postgis installer found at
> http://dcmms.sourceforge.net/postgis_installer.php
> After some test (failed) with mapserver, I tryed to execute very
> simple query like:
> CREATE TABLE gtest ( ID int4, NAME varchar(20) );
> SELECT AddGeometryColumn('dbname','gtest','geom',-1,'LINESTRING',2);
> INSERT INTO gtest (ID, NAME, GEOM) VALUES (1, 'First Geometry',
> GeometryFromText('LINESTRING(2 3,4 5,6 5,7 8)', -1));
> SELECT id, name, AsText(geom) AS geom FROM gtest;
> id | name | geom
> 1 | First Geometry | LINESTRING(2 3,4 5,6 5,7 8)
> SELECT id,name FROM GTEST WHERE GEOM && 'BOX3D(3 4,4 5)'::box3d;
> this query crashes the postgres.exe process on "windows XP home SP1"
> Can this depend on the OS?
> thanks,
> RedS
Dear Stefano,
obviosly it does, my WinMapserver/Mapscript 4.2.3 (the same with 4.2.2)
from maptools.org is not crashing PostgreSQL anymore and the error line
is slightly nicer ;-):
*Warning*: [MapServer Error]: prep_DB(): Couldnt recover from a bad
query: 'DECLARE mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),OID::text from not1
WHERE the_geom && setSRID('BOX3D(365000 8906.25,635000
211093.75)'::BOX3D, find_srid('','not1','the_geom') )' in ...
The problem probably lies in the libpq.dll (version 1.2.2003)
used/contained in the zip file) by this Mapserver.
Looks to be too rather old.
Which version of Mapserver are you using?
BR
Mladen
Mladen Kotarac, univ.dipl.biol.
Center za kartografijo favne in flore
Centre for Cartography of Fauna and Flora
http://www.ckff.si
Antoliciceva 1, SI-2204 Miklavž na Dravskem polju, Slovenija
tel: 00386-(0)2-6295150
fax: 00386-(0)2-6295151
podružnica Ljubljana, Zemljemerska 10, SI-1000 Ljubljana, Slovenija
tel: 00386-(0)1-4382440
fax: 00386-(0)1-4382445
GSM: 00386-(0)41-735429
e-mail: mladen.kotarac at ckff.si
