Getting shape values from a PostGIS layer - i really need help
Mathieu Parent
mathieuparent at INFONIE.FR
Sat Sep 4 07:28:00 EDT 2004
Mathieu Parent a écrit :
> Hi,
> How can I get values when I make a query in PHP/MapScript on a PostGIS
> layer ?
> Examples :
> _layer's properties :_
> CONNECTION "user=user password=pass dbname=postgis host=localhost
> port=5432"
> CONNECTIONTYPE POSTGIS
> DATA "the_geom from adres"
> _part of the script :_
> if(($num_results=$layer->getNumResults())>0) {
> $layer->open();
> for($j=0;$j<$num_results;$j++) {
> $result=$layer->getResult($j);
> $shape=$layer->getShape($result->tileindex,$result->shapeindex);
> foreach($shape->values AS $field=>$value) {
> echo "$field=>$value<br>\n";
> $layer->close();
> thanks
The problem is : $shape->values is an empy array (because $layer is not
a ShapeFile)
how can i get the values associated with the geom ?
