Colors, PNGs
Frieso ter Haseborg
ter-haseborg at SF-DATENTECHNIK.DE
Mon Sep 6 09:44:50 EDT 2004
looks like the ortho images consume the whole palette, you could try to reduce this effect by using the processing parameter on the ortho-layer.
LAYER
NAME "ortho"
TYPE RASTER
PROCESSING 'COLOR_MATCH_THRESHOLD=3'
Start with a setting of 3 and increase this value until it fits your needs.
hth,
Frieso ter Haseborg
- Software Development -
S&F Datentechnik GmbH&Co.KG
Reimersstr. 41b
26789 Leer, Germany
> -----Original Message-----
> From: Titus von der Malsburg [mailto:malsburg at CL.UNI-HEIDELBERG.DE]
> Sent: Monday, September 06, 2004 1:28 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] Colors, PNGs
> Hi,
> I have a problem with colors in maps rendererd by Mapserver when using
> png as the outputformat. I have two layers: a raster layer with
> black&white ortho imagery and a shape showing buildings in different
> colors. The layers a look as expected when rendered
> individually. See:
> * http://www.cl.uni-heidelberg.de/~malsburg/temp/mapserv03.png
> * http://www.cl.uni-heidelberg.de/~malsburg/temp/mapserv01.png
> But if I switch them both on, it looks like
> * http://www.cl.uni-heidelberg.de/~malsburg/temp/mapserv02.png
> Everything is black&white. The problem does only appear with
> outputformat set to png.
> Does anyone know how to solve this problem?
> Thanks,
> Titus
> $ mapserv -v
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
> SUPPORTS=PROJ
> SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7
> INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> On Debian unstable.
