compile problems --- make: *** [shp2img] Error 1
Shawn Barnes
barnes at WATERSHEDS.CA
Fri Sep 10 13:50:56 EDT 2004
I'm having problems compiling mapserver i get shp2img error during the
make.
This is the error i get,
/usr/SRC/gdal-1.2.1/libgdal.la: file not recognized: File format not
recognized
collect2: ld returned 1 exit status
I'm using the current nightlybuild, downloaded about an hour ago.
And these are my configure options,
--with-freetype=/usr/local/bin/freetype-config \
--with-zlib \
--with-png \
--with-jpeg /usr/lib \
--with-xpm=no \
--with-gd \
--with-proj=../proj-4.4.8 \
--with-ogr=../gdal-1.2.1/apps/gdal-config \
--with-gdal=../gdal-1.2.1/apps/gdal-config \
--with-tiff \
--with-postgis=/usr/local/pgsql/bin/pg_config \
--with-wfs \
--with-wmsclient \
--with-wfsclient \
--with-curl-config=/usr/local/bin/curl-config \
--with-httpd=/usr/sbin/apache \
--with-php=../php-4.3.8
Thanks,
Shawn
