HELP, mode=map returns text string not image (KNOW BUG??).
Ed McNierney
ed at TOPOZONE.COM
Mon Sep 13 13:04:47 EDT 2004
Reuven -
Is your Tomcat environment expecting/able to handle the image type
(PNG?) being returned?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA 01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Reuven Levitt
Sent: Monday, September 13, 2004 12:55 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] HELP, mode=map returns text string not
image (KNOW BUG??).
I am running MS4.2 on WinXP over Tomcat.
I am using a very simple Map file that creates a single layer (see
below).
When mode=browse it works fine, but when I use mode=img it either
returns a long string of unicode characters, or it returns the following
exception:
java.lang.StringIndexOutOfBoundsException: String index out of range: 0
at java.lang.String.charAt(String.java:444)
at
org.apache.coyote.Response.addHeader(Response.java:374)
at
org.apache.coyote.tomcat4.CoyoteResponse.addHeader(CoyoteResponse.java:8
97)
at
org.apache.coyote.tomcat4.CoyoteResponseFacade.addHeader(CoyoteResponseF
acade.java:383)
at
org.apache.catalina.servlets.CGIServlet$CGIRunner.run(CGIServlet.java:18
44)
at
org.apache.catalina.servlets.CGIServlet.doGet(CGIServlet.java:640)
Is there a know problem, or am I doing something terribly wrong?
Thanks,
Reuven.
LAYER
NAME "credits"
STATUS default
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
200 150
END
TEXT 'This is a test of the ability to
display text.'
END
CLASS
LABEL
TYPE BITMAP
COLOR 255 0 0
END
END
END
