HELP, mode=map returns text string not image (KNOW BUG??).
Reuven Levitt reuven at LEVITT.NET
Mon Sep 13 14:19:01 EDT 2004
I actually did mean "mode=map".
That is what i used, "mode=img" was a typo
> >I am running MS4.2 on WinXP over Tomcat.
> >I am using a very simple Map file that creates a
> >single layer (see below).
> >When mode=browse it works fine, but when I use
> >mode=img it either returns a long string of unicode
> >characters, or it returns the following exception:
> >java.lang.StringIndexOutOfBoundsException: String
> >index out of range: 0
> >         at
> java.lang.String.charAt(String.java:444)
> >         at
>org.apache.coyote.Response.addHeader(Response.java:374)
> >         at
>org.apache.coyote.tomcat4.CoyoteResponse.addHeader(CoyoteResponse.java:897)
> >         at
>org.apache.coyote.tomcat4.CoyoteResponseFacade.addHeader(CoyoteResponseFacade.java:383)
> >         at
>org.apache.catalina.servlets.CGIServlet$CGIRunner.run(CGIServlet.java:1844)
> >         at
>org.apache.catalina.servlets.CGIServlet.doGet(CGIServlet.java:640)
> >Is there a know problem, or am I doing something
> >terribly wrong?
> >Thanks,
> >Reuven.
> >                 LAYER
> >                         NAME "credits"
> >                         STATUS default
> >                         TRANSFORM FALSE
> >                         TYPE ANNOTATION
> >                         FEATURE
> >                                 POINTS
> >                                         200 150
> >                                 END
> >                                 TEXT 'This is a
> test of the ability to
> >display
> >text.'
> >                         END
> >                         CLASS
> >                                 LABEL
> >                                         TYPE
> BITMAP
> >                                         COLOR 255
> 0 0
> >                                 END
> >                         END
> >                 END
_________________________________________________________________
> MSN 8 helps eliminate e-mail viruses. Get 2 months
> FREE*.
> http://join.msn.com/?page=features/virus
