Mapserver Web service questions
ANDY CANFIELD andy_canfield at HOTMAIL.COM
Wed Sep 15 11:55:46 EDT 2004
Ed,
That is essentially what I was looking for.
So I can send and http request to it via a small device and have it return
an image directly?
Or does it put the image in a directory on the server from which I must
retrieve it via an io stream?
If I go the web service route it will be a MIDlet on a phone making the
request then embeding the image on the MIDlet's displayable canvas much like
ROSA does in Applet context. However ROSA pulls from a link essentially to
where the image has been created on the server.
Also in the GET request how do you specify layers off or on etc? Or do you
have to send a PUT type request first to configure the output that a GET
will return?
So far I have only used the php Interface so my knowlege of the actual
Mapserver itself is weak.
Thanks,
Andy
>From: Ed McNierney <ed at TOPOZONE.COM>
>Reply-To: Ed McNierney <ed at TOPOZONE.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Mapserver Web service questions
>Date: Wed, 15 Sep 2004 11:01:57 -0400
>Andy -
>"Web service" is a pretty loose term; do you have specific interface
>constraints (i.e. a particular interface model, etc.)?  MapServer
>natively supports the OGC Web Map Service (WMS) that provides a very
>nice, simple way to make an HTTP GET request that returns a image file
>in the requested format.  Such a request can be easily used in, for
>example, the "src=" property of an <IMG> tag on the requesting page.  It
>can, of course, also be used in more complex environments where the
>client/requester is a different sort of application than a simple HTML
>viewer.
>         - Ed
>Ed McNierney
>President and Chief Mapmaker
>TopoZone.com / Maps a la carte, Inc.
>73 Princeton Street, Suite 305
>North Chelmsford, MA  01863
>ed at topozone.com
>(978) 251-4242
>-----Original Message-----
>From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
>Behalf Of ANDY CANFIELD
>Sent: Wednesday, September 15, 2004 10:45 AM
>Subject: [UMN_MAPSERVER-USERS] Mapserver Web service questions
>To anyone who may know,
>         Can Mapserver be used like a web service?
>Here is my situation. I have a small device that I want to show maps on.
>There are two ways I can do this as the device has a browser I can make
>a small web page for it, or to give it more functionality I can write an
>embeded app that displays maps from a web service.
>So what I need to know is can Mapserver be used like a web service or do
>I need to write a web service that acts as the interface to Mapserver?
>I am using Mapserver for Windows and currently it's set up with php
>Mapscript for my web maps.
>If I can use Mapserver as a service can I use the same one I'm running
>php Mapscript against?
>If not and I write a service is it safe to target the same Mapserver as
>php is using via it's Mapscript interface?
>If it helps any the device sending the requests will be a Nextel
>Blackberry.
>The language of the app sitting on the device will be J2ME ( Java Micro
>Edition ). The service itself if I have to write one will be in C++.
>Any help or suggestions would be greatly appreciated.
>Thanks,
>Andy
>_________________________________________________________________
>Don't just search. Find. Check out the new MSN Search!
>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Don’t just search. Find. Check out the new MSN Search!
