Mapserver Web service questions
Ed McNierney ed at TOPOZONE.COM
Wed Sep 15 12:35:23 EDT 2004
Andy -
Please start by reading the WMS Client and Server documentation, which
you can find at http://mapserver.gis.umn.edu/doc.html - it's very simple
to use.
        - Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
ed at topozone.com
(978) 251-4242
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of ANDY CANFIELD
Sent: Wednesday, September 15, 2004 11:56 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Mapserver Web service questions
Ed,
That is essentially what I was looking for.
So I can send and http request to it via a small device and have it
return an image directly?
Or does it put the image in a directory on the server from which I must
retrieve it via an io stream?
If I go the web service route it will be a MIDlet on a phone making the
request then embeding the image on the MIDlet's displayable canvas much
like ROSA does in Applet context. However ROSA pulls from a link
essentially to where the image has been created on the server.
Also in the GET request how do you specify layers off or on etc? Or do
you have to send a PUT type request first to configure the output that a
GET will return?
So far I have only used the php Interface so my knowlege of the actual
Mapserver itself is weak.
Thanks,
Andy
>From: Ed McNierney <ed at TOPOZONE.COM>
>Reply-To: Ed McNierney <ed at TOPOZONE.COM>
>Date: Wed, 15 Sep 2004 11:01:57 -0400
>Andy -
>"Web service" is a pretty loose term; do you have specific interface
>constraints (i.e. a particular interface model, etc.)?  MapServer
>natively supports the OGC Web Map Service (WMS) that provides a very
>nice, simple way to make an HTTP GET request that returns a image file
>in the requested format.  Such a request can be easily used in, for
>example, the "src=" property of an <IMG> tag on the requesting page.
>It can, of course, also be used in more complex environments where the
>client/requester is a different sort of application than a simple HTML
>viewer.
>         - Ed
>Ed McNierney
>ed at topozone.com
>(978) 251-4242
>On Behalf Of ANDY CANFIELD
>Sent: Wednesday, September 15, 2004 10:45 AM
>Subject: [UMN_MAPSERVER-USERS] Mapserver Web service questions
>To anyone who may know,
>         Can Mapserver be used like a web service?
>Here is my situation. I have a small device that I want to show maps
on.
>There are two ways I can do this as the device has a browser I can make
>a small web page for it, or to give it more functionality I can write
>an embeded app that displays maps from a web service.
>So what I need to know is can Mapserver be used like a web service or
>do I need to write a web service that acts as the interface to
Mapserver?
>I am using Mapserver for Windows and currently it's set up with php
>Mapscript for my web maps.
>If I can use Mapserver as a service can I use the same one I'm running
>php Mapscript against?
>If not and I write a service is it safe to target the same Mapserver as
>php is using via it's Mapscript interface?
>If it helps any the device sending the requests will be a Nextel
>Blackberry.
>The language of the app sitting on the device will be J2ME ( Java Micro
>Edition ). The service itself if I have to write one will be in C++.
>Any help or suggestions would be greatly appreciated.
>Thanks,
>Andy
>_________________________________________________________________
>Don't just search. Find. Check out the new MSN Search!
>http://search.msn.click-url.com/go/onm00200636ave/direct/01/
