Fwd: error
Mladen Kotarac
mladen.kotarac at CKFF.SI
Thu Sep 16 11:03:57 EDT 2004
Steve Lime wrote:
> Subject:
> error
> From:
> "ry4n" <iyan at salatigacamp.com>
> Date:
> Thu, 16 Sep 2004 09:03:20 +0700
> To:
> <mapserver-bugs at lists.gis.umn.edu>
> To:
>Warning: Function registration failed - duplicate name - ms_newmapobj in
>c:\program files\apache group\apache\htdocs\php\test.php on line 7
You probably have the mapscript.dll also loaded by PhP by default.
Check your php.ini.
There are two options:
1. To load mapscript.dll with php by default (uncheck it in the list of
extensions in php.ini)
OR
2. To load it at the execution time (when needed) the way it is in your
script.
Both at the same time do NOT work, since obviously double registration
of functions is not possible.
BR
Mladen
Mladen Kotarac, univ.dipl.biol.
Center za kartografijo favne in flore
Centre for Cartography of Fauna and Flora
http://www.ckff.si
Antoliciceva 1, SI-2204 Miklavž na Dravskem polju, Slovenija
tel: 00386-(0)2-6295150
fax: 00386-(0)2-6295151
podružnica Ljubljana, Zemljemerska 10, SI-1000 Ljubljana, Slovenija
tel: 00386-(0)1-4382440
fax: 00386-(0)1-4382445
GSM: 00386-(0)41-735429
e-mail: mladen.kotarac at ckff.si
