utility programs
Dylan Keon
keon at NACSE.ORG
Thu Sep 16 17:01:16 EDT 2004
On 09/16/2004 01:33 PM, John Bolster wrote:
> Hello,
> I am trying to use the tile4ms utility and I can't find the executable file.
> Mapserver is installed on FreeBSD from a package. Any hints on where I
> should look and am I looking for a file called just tile4ms with no
> extension?
> If it wasn't included in the package, how do I create just this utility from
> the distribution?
John,
Yes, 'tile4ms' with no extension.
I haven't used FreeBSD, but I bet there's a standard place where
packages install executables (like /usr/bin on Redhat). Otherwise, have
you tried using the 'find' command to search across your system?
If you want to build just tile4ms you could build mapserver from source,
then copy out tile4ms and delete the rest. Or build mapserver from
source and just use it all instead of using the package :-)
--Dylan
