Javascript, queries, and frames
Rebecca Colwell colwell at GEOG.UMN.EDU
Fri Sep 17 14:50:19 EDT 2004
Hi all,
Many thanks to Brant and Tyler for their input on my problem.  :D
The solution that got me up and running was to create a frame.html doc
with two frames.  The key for making it work in the end was to name the
frame I wanted to direct query results in the frame.html doc.
<FRAMESET ROWS="79%,*">
        <FRAME
SRC="http://mapserver.geog.umn.edu/cgi-bin/mapserv?map=/home/name/public_html/Mapdoc/Map1.map&mode=browse">
        <frame name="QueryResults" src="templates/frame1.html" noresize>
</FRAMESET>
Thanx again!
~Becky
Brant Anderson wrote:
> Hi Rebecca,
> I'll try to help you the best I can... But no promises. ;-)
> I haven't worked with targeted forms at all, but in theory, your code
> looks pretty good. As far as your "frame code" goes, I think you need
> two frames in the frameset. For example:
> <frameset cols="214">
>    <frame name="MapFrame" src="templates/frame0.html"> <!-- this frame
> is your main application frame -->
>    <frame name="QueryResults" src="templates/frame1.html" noresize> <!--
> this frame is used for your query results -->
> </frameset>
> You'll most likely need to modify my "persay" frameset page to make the
> page look how you want it. The main point is that you will need two
> Could you give an example of how the page is acting with your current
> code? Have you taken a look at the Itasca demo? It uses frames, but it's
> done in a different way using JavaScript to pull the information from
> MapServer, instead of assigning a target frame.
> Hope I was helpful!
> Brant
> Rebecca Colwell wrote:
>> Hi all,
>> I'm trying to query my map and have the resulting information appear in
>> a frame in the right hand side column of a table.  I've been reading
>> past listserv responses for a week and haven't found the answer I'm
>> looking for.  I've provided the code I think corresponds with my problem
>> below.
>> I don't know a few things that I would love to get some feedback on.
>> 1.) Does the javascript I have look right?
>> 2.) What code do I need to have in my "Map Mode" menu (see below) to get
>> the query results to send to a frame in the main map html?
>> 3.) Can a frame exist in an html document as a stand alone frame?  For
>> instance, I would like the query info to display in the white space
>> below my legend.  The legend exists within a table column and I've
>> placed the frameset code below the legend.
>> If you see any other glaring errors in my logic, please feel free to
>> point it out.
>> Thank you,
>> ~Becky
>> For the javascript code, I have the following:
>> //Checks Target
>> function CheckTarget(){
>> if (document.mapserv.mode.value == "query"){
>> document.mapserv.target="QueryResults";}
>> else{
>> document.mapserv.target="";
>> At the beginning of my form I have:
>> <form name="mapserv" method="GET" action="/cgi-bin/mapserv"
>> onSubmit="CheckTarget();" target="QueryResults">
>> In my Map Mode dropdown menu I have:
>> Map Mode:<br>
>>        <select name="mode">
>>        <option value="browse">Browse</option>
>>        <option value="map">Map</option>
>>        <option value="query" [query_select]>Query Single Layer</option>
>>         <option value="query" [mode_query_select]> Query State Info
>>        </select>
>> My frame code:
>> <frameset
>> cols="214">
>> </frameset>
