About ordering of layers.
Bob Basques
bob.basques at CI.STPAUL.MN.US
Mon Sep 20 11:42:55 EDT 2004
All,
It seems that the LAYERs are interpreted in the MAP file from the top
down for processing.
I've managed to get the grouping of LAYERS to work for IMAGEMAPs as
well. It looks like the process reads from the bottom to the top though
for the IMAGEMAP generation when more than one definition is available.
This for example produces the correct IMAGEMAP (notice the order of the
commented out TEMPLATE parameters):
LAYER
NAME 'monuments-cogo'
DATA
'/pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/MONUMENTS/SURVEY/2004_09/COGO/Monuments-cogo'
GROUP 'monuments'
STATUS DEFAULT
TYPE POINT
LABELITEM 'OLD'
##LABELITEM 'COGO'
CLASS
OUTLINECOLOR 0 0 0
LABEL
FORCE TRUE
COLOR 255 200 200
OUTLINECOLOR 0 0 0
SIZE LARGE
WRAP ' '
END
END
##HEADER '../../imagemap/monuments_header.html'
TEMPLATE '../../imagemap/monuments_record.html'
FOOTER '../../imagemap/monuments_footer.html'
END
LAYER
NAME 'monuments-nocogo'
DATA
'/pearl/SHP/SAINT_PAUL/PUBLIC_WORKS/MONUMENTS/SURVEY/2004_09/NOCOGO/Monuments-nocogo'
GROUP 'monuments'
STATUS DEFAULT
TYPE POINT
LABELITEM 'OLD'
##LABELITEM 'COGO'
CLASS
OUTLINECOLOR 0 0 0
LABEL
FORCE TRUE
COLOR 200 200 255
OUTLINECOLOR 0 0 0
SIZE LARGE
WRAP ' '
END
END
TEMPLATE '../../imagemap/monuments-nocogo_record.html'
##FOOTER '../../imagemap/monuments_footer.html'
END
Is this normal operation? Is there some ordering directive someplace
that can be inserted to dictate at what point a LAYER is drawn?
Thanks bobb
