points in a multipolygon set from oraclespatial
Judd, Chris
Chris.Judd at DEP.STATE.FL.US
Thu Sep 23 10:07:02 EDT 2004
I'm not sure, but I think you might run into an issue with MapServer if you
are mixing geometry types. I haven't tested this myself, but MapServer can
support only one geometry type for each layer. With that said I have heard
that MapServer can support polys and lines in a single layer but most likely
points would not work.
Hope this helps.
-Chris
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of GIRAUD Pierre
Sent: Thursday, September 23, 2004 9:34 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] points in a multipolygon set from
oraclespatial
I'm new to Oracle, that's probably why that wasn't clear for me. '1003'
gtype is not for a point but for polygons too.
Actually, the '2007' multipolygons with '1003' elements are polygons
with holes. I'm sorry for this obvious mistake.
Althouh, I do have the problem that OGR connection crashes,
oraclespatial connection not on those type of geometry.
Pierre
GIRAUD Pierre wrote:
> Hi list,
> Today, I'm in front of a particular problem. For a customer, I need to
> render oraclespatial data.
> In the database, I have shapes with a '2007' SDO_GTYPE, that says
> multipolygons. Hopelessly, in the SDO_ELEM_INFO_ARRAY, including the
> polygons (2003), some points (1003) can be found. Curious for a
> multipolygon, and you might want to say that it'd better be a Collection
> (2004) ! But I can't modify data.
> The problem is that if define my layer with an oraclespatial
> connectiontype, the layer is rendered. On the other hand, with an
> OGR/OCI connectiontype, mapserver crashes.
> Any idea ?
> Pierre GIRAUD
> camptocamp
