PHP ms_newLayerObj vs SWIG layerObj
Ryan, Adam
ARyan at CO.LINN.OR.US
Thu Sep 23 17:02:43 EDT 2004
Thanks for the update. I can't think of a reason for cloning a layer other
than inserting into a map, so it may not be needed. Don't know.
Thanks again,
Adam
-----Original Message-----
Sent: Thursday, September 23, 2004 1:42 PM
To: Ryan, Adam
Cc: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: PHP ms_newLayerObj vs SWIG layerObj
On Sep 23, 2004, at 2:24 PM, Ryan, Adam wrote:
> Am I missing something simple?
> In PHP I'm able to take a layer from one map and add it to another map
> using
> ms_newLayerObj($map_object,$layer_object_from_another_map);
> Is there a way to do this with SWIG mapscript. The layerObj method
> takes
> only one argument - the map. Is there a clone() for layers or
> something
> like that?
> Adam
Adam,
Not in the 4.2 version. In the 4.4 release, you'll be able to by using
mapObj::insertLayer which adds a copy of any layer to the map. If you want
layerObj::clone in the next version, submit a request in Bugzilla and I'll
get around to it.
Sean
Sean Gillies
sgillies at frii dot com
http://users.frii.com/sgillies
