projection lon_0
jan hartmann j.l.h.hartmann at UVA.NL
Fri Sep 24 12:03:28 EDT 2004
John Bolster wrote:
> Hi all,
> Thanks to all of you who have helped me so far.
> I'm attempting to reproduce the projection used by the Census Bureau in
> their Tiger map browser. It's a sinusoidal projection, but it appears to be
> centered at the center of the rendered map each time rather than having one
> origin. If I set my projection to sinu and manually set lon_0 to the same as
> the map center it looks right, but I want lon_0 to automatically follow the
> map center.
> Is there any value I can pass in the url to set the lon_0 each time? I've
> tried &map_projection_lon_0= and it doesn't work. Any ideas?
> Thanks,
> John
Hi John,
You have to specify the complete projection string as part of the URL:
&map_projection=proj=sinu,lon_0=...
HTH
Jan
