projection lon_0
John Bolster
jb at NUCOMP.COM
Fri Sep 24 11:49:01 EDT 2004
Hi all,
Thanks to all of you who have helped me so far.
I'm attempting to reproduce the projection used by the Census Bureau in
their Tiger map browser. It's a sinusoidal projection, but it appears to be
centered at the center of the rendered map each time rather than having one
origin. If I set my projection to sinu and manually set lon_0 to the same as
the map center it looks right, but I want lon_0 to automatically follow the
map center.
Is there any value I can pass in the url to set the lon_0 each time? I've
tried &map_projection_lon_0= and it doesn't work. Any ideas?
Thanks,
John
