WMS_client image format problems
Arnulf Christl
arnulf.christl at CCGIS.DE
Fri Sep 24 13:28:02 EDT 2004
K. Lessing wrote:
> Dear List,
> I am running MapServer 4.2.3 at least with WMS_client capabilities.
> I try to capture one layer "laender" out from www.geoway.de.
the capabilties request
http://192.168.23.151/mapserv.cgi?map=/home/geoway/geoway.map&WMTVER=1.0.0&REQUEST=capabilities
does not return anything but a "timed out..."
Maybe the server you try to access is just not available.
Cheers, Arnulf.
> The whole bundle of layers can be seen here:
> http://www.geoway.de/cgi-bin/mapserv3.cgi?MAP=/home/geoway/geoway.map&VERSION=1.1.0&REQUEST=GetMap&&SRS=EPSG:32632&BBOX=280450,5236000,921400,6102500
> The geoway MapServer seams to produce images which are stored in my
> directory:
> /srv/www/htdocs/tmp/
> Unfortunally the suffix of the files which are stored in my directory
> and which my MapServer is trying to display are looking strange:
> *.img.tmp
> Does anybody know if I configured something wrong?
> (My Mapfile in the following)
> best regards and
> many thanx beforehand
> Karsten
> MAP
> NAME Testfile
> SHAPEPATH "../daten"
> SYMBOLSET "../docs/symbol.txt"
> FONTSET "/srv/www/htdocs/fonts/fonts.txt"
> EXTENT 280460 5235969 921383 6102410
> STATUS ON
> SIZE 400 400
> WEB
> TEMPLATE "temp0.html"
> IMAGEPATH "/srv/www/htdocs/tmp/"
> IMAGEURL "/tmp/"
> END
> PROJECTION
> "init=EPSG:32632"
> END
> OUTPUTFORMAT
> NAME "Farbenfroh"
> DRIVER "GD/png"
> MIMETYPE "image/png"
> IMAGEMODE RGB
> EXTENSION "png"
> END
> LAYER
> NAME "laender"
> TYPE VECTOR
> STATUS DEFAULT
> CONNECTION "http://www.geoway.de/cgi-bin/geoway.map?"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:32632"
> "wms_name" "laender"
> "wms_server_version" "1.1.0"
> "wms_formatlist" "image/png"
> "wms_format" "image/png"
> END
> END
> END
CCGIS Christl & Stamm GbR
http://www.ccgis.de
http://www.mapbender.org
Service: +49 (0)228 90826 0
Direct: +49 (0)228 90826 23
Fax: +49 (0)228 90826 11
Siemensstraße 8
53121 Bonn
GERMANY
