WMS_client image format problems
K. Lessing
umn at KARSTEN-LESSING.DE
Fri Sep 24 13:43:46 EDT 2004
Hi Arnulf,
thanx for your answer.
If you try this:
http://www.geoway.de/cgi-bin/mapserv3.cgi?MAP=/home/geoway/geoway.map&VERSION=1.1.0&REQUEST=GetCapabilities
the Server answers with an xml file:
Unfortunatelly I could not find any helpful information in this xml file!
regards
Karsten
Arnulf Christl schrieb:
> K. Lessing wrote:
>> Dear List,
>> I am running MapServer 4.2.3 at least with WMS_client capabilities.
>> I try to capture one layer "laender" out from www.geoway.de.
> Hi,
> the capabilties request
> http://192.168.23.151/mapserv.cgi?map=/home/geoway/geoway.map&WMTVER=1.0.0&REQUEST=capabilities
> does not return anything but a "timed out..."
> Maybe the server you try to access is just not available.
> Cheers, Arnulf.
>> The whole bundle of layers can be seen here:
>> http://www.geoway.de/cgi-bin/mapserv3.cgi?MAP=/home/geoway/geoway.map&VERSION=1.1.0&REQUEST=GetMap&&SRS=EPSG:32632&BBOX=280450,5236000,921400,6102500
>> The geoway MapServer seams to produce images which are stored in my
>> directory:
>> /srv/www/htdocs/tmp/
>> Unfortunally the suffix of the files which are stored in my directory
>> and which my MapServer is trying to display are looking strange:
>> *.img.tmp
>> Does anybody know if I configured something wrong?
>> (My Mapfile in the following)
>> best regards and
>> many thanx beforehand
>> Karsten
>> MAP
>> NAME Testfile
>> SHAPEPATH "../daten"
>> SYMBOLSET "../docs/symbol.txt"
>> FONTSET "/srv/www/htdocs/fonts/fonts.txt"
>> EXTENT 280460 5235969 921383 6102410
>> STATUS ON
>> SIZE 400 400
>> WEB
>> TEMPLATE "temp0.html"
>> IMAGEPATH "/srv/www/htdocs/tmp/"
>> IMAGEURL "/tmp/"
>> END
>> PROJECTION
>> "init=EPSG:32632"
>> END
>> OUTPUTFORMAT
>> NAME "Farbenfroh"
>> DRIVER "GD/png"
>> MIMETYPE "image/png"
>> IMAGEMODE RGB
>> EXTENSION "png"
>> END
>> LAYER
>> NAME "laender"
>> TYPE VECTOR
>> STATUS DEFAULT
>> CONNECTION "http://www.geoway.de/cgi-bin/geoway.map?"
>> CONNECTIONTYPE WMS
>> METADATA
>> "wms_srs" "EPSG:32632"
>> "wms_name" "laender"
>> "wms_server_version" "1.1.0"
>> "wms_formatlist" "image/png"
>> "wms_format" "image/png"
>> END
>> END
>> END
> CCGIS Christl & Stamm GbR
> http://www.ccgis.de
> http://www.mapbender.org
> Service: +49 (0)228 90826 0
> Direct: +49 (0)228 90826 23
> Fax: +49 (0)228 90826 11
> Siemensstraße 8
> 53121 Bonn
> GERMANY
