Tiling Large Rasters
Frank Warmerdam
warmerdam at POBOX.COM
Tue Sep 28 12:54:43 EDT 2004
Titus von der Malsburg wrote:
> Hi,
> normally I tile raster images with a little script that uses netpbm to
> load the data und cut out the tiles. But now I have an image to tile
> that is too large to be loaded into memory.
> Actually it should be possible to do the tiling with constant memory
> consumption (ammount of memory not depending on the size of the image).
> Is there any software out there that accomplishes this task?
> I looked briefly into the documentation of Grass but couldn't find
> anything.
Titus,
There is user written code for a program based on GDAL that will accomplish
this task in bug:
http://bugzilla.remotesensing.org/show_bug.cgi?id=604
You are on your own to build and test it through. I haven't tried it yet.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
