GetCapabilities
David Zwiers dzwiers at REFRACTIONS.NET
Wed Sep 29 14:17:21 EDT 2004
Tom,
My comment was more to the effect that I believe some attributes are
missing in the documents returned. The current implementation has this
as the first element:
<WFS_Capabilities version="1.0.0" updateSequence="0"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
but I believe that since both the default namespace has not been set,
and the xsi namespace has not been set, the schemaLocation attribute is
meaningless to a generic parser. I also do not believe that the
capabilities document would validate.
My recommendation is to add the the following two attributes to have the
element looks like this:
xmlns="http://www.opengis.net/wfs"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
Yours,
David
On Wed, 2004-09-29 at 10:51, Kralidis,Tom [Burlington] wrote:
> The default namespace is http://www.opengis.net/wfs
> > -----Original Message-----
> > From: UMN MapServer Users List
> > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of David Zwiers
> > Sent: Wednesday, 29 September, 2004 13:37
> > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > Subject: [UMN_MAPSERVER-USERS] GetCapabilities
> > Hello List
> > Apologies in advance if this is an older bug, but I couldn't
> > find it in your bug tracker. I am creating a WFS client, and
> > selected your WFS as one of my victims :).  When reading the
> > capabilities document, you have forgotten to declare the
> > default namespace on the server instances I have seen
> > (included below).
> > I was wondering if these servers are out of date, and if so
> > where I could find a demo server to test against. (BTW the
> > code is freely available in the geotools project).
> > Thanks in advance,
> > David Zwiers
> http://map.ns.ec.gc.ca/MapServer/mapserv.exe?map=/mapserver/services/env
> dat/config.map&service=WFS&version=1.0.0&request=GetCapabilities
> http://excise.pyr.ec.gc.ca/cgi-bin/mapserv.exe?map=/LocalApps/Mapsurfer/
> PYRWQMP.map&version=1.0.0&service=WFS&request=GetCapabilities
