GetCapabilities
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Wed Sep 29 14:22:46 EDT 2004
> -----Original Message-----
> From: David Zwiers [mailto:dzwiers at refractions.net]
> Sent: Wednesday, 29 September, 2004 14:17
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: RE: [UMN_MAPSERVER-USERS] GetCapabilities
> Tom,
> My comment was more to the effect that I believe some
> attributes are missing in the documents returned. The current
> implementation has this as the first element:
> <WFS_Capabilities version="1.0.0" updateSequence="0"
> xsi:schemaLocation="http://www.opengis.net/wfs
> http://schemas.opengis.net/wfs/1.0.0/WFS-capabilities.xsd">
> but I believe that since both the default namespace has not
> been set, and the xsi namespace has not been set, the
> schemaLocation attribute is meaningless to a generic parser.
> I also do not believe that the capabilities document would validate.
Both WMS targets use MapServer 4.2.0, and both define the xsi namespace,
as well as http://www.opengis.net as the default namespace of the
document, as well as the xsi:schemaLocation directive properly.
Both documents validate fine. If you're debugging looking at response
through something like Mozilla, you may want to "view source" to see the
XML response in its entirety.
Cheers
..Tom
> My recommendation is to add the the following two attributes
> to have the element looks like this:
> xmlns="http://www.opengis.net/wfs"
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> Yours,
> David
> On Wed, 2004-09-29 at 10:51, Kralidis,Tom [Burlington] wrote:
> > The default namespace is http://www.opengis.net/wfs
> > > From: UMN MapServer Users List
> > > [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of David Zwiers
> > > Sent: Wednesday, 29 September, 2004 13:37
> > > To: MAPSERVER-USERS at LISTS.UMN.EDU
> > > Subject: [UMN_MAPSERVER-USERS] GetCapabilities
> > > Hello List
> > > Apologies in advance if this is an older bug, but I couldn't
> > > find it in your bug tracker. I am creating a WFS client, and
> > > selected your WFS as one of my victims :). When reading the
> > > capabilities document, you have forgotten to declare the
> > > default namespace on the server instances I have seen
> > > (included below).
> > > I was wondering if these servers are out of date, and if so
> > > where I could find a demo server to test against. (BTW the
> > > code is freely available in the geotools project).
> > > Thanks in advance,
> > > David Zwiers
> http://map.ns.ec.gc.ca/MapServer/mapserv.exe?>
map=/mapserver/services/e
> > nv
> > dat/config.map&service=WFS&version=1.0.0&request=GetCapabilities
> http://excise.pyr.ec.gc.ca/cgi->
bin/mapserv.exe?map=/LocalApps/Mapsurfe
> > r/
> > PYRWQMP.map&version=1.0.0&service=WFS&request=GetCapabilities
