SWIG Mapscript
Ryan, Adam
ARyan at CO.LINN.OR.US
Thu Sep 30 12:03:34 EDT 2004
> -----Original Message-----
> From: Umberto Nicoletti [mailto:unicoletti at PROMETEO.IT]
> Sent: Thursday, September 30, 2004 12:08 AM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] SWIG Mapscript
> Hi Adam,
> some time time ago I also wanted to use save/loadQuery from
> Java mapscript. My workaround is to save query parameters in
> the user's session and run the query every time until it is
> cleared on explicit user request or another query is run.
> This keeps the result consistent even if the user changes
> layers display properties (hides/shows a layer).
> I did not notice any significant slowdown.
> HTH,
> Umberto
> > > From: Sean Gillies [mailto:sgillies at FRII.COM]
> > > Sent: Wednesday, September 29, 2004 12:19 PM
> > > On Sep 29, 2004, at 1:16 PM, Sean Gillies wrote:
> > > > On Sep 29, 2004, at 12:54 PM, Ryan, Adam wrote:
> > > >> Mapservers,
> > > >> Two methods I use in php mapscript don't seem to be in
> the SWIG
> > > >> version.
> > > >> Layer->queryByIndex - this is non-critical since I can use
> > > >> queryByAttribute
> > > >> with an FID
> > > >> Map->loadQuery - this is critical. There is a saveQuery
> > > method, but
> > > >> no
> > > >> loadQuery?
> > > >> Thanks for any insight.
> > > >> Adam
> > > > Adam,
> > > > Since I've used the PHP mapscript, I'm not sure what
> loadQuery and
> > > > saveQuery are for. Explain?
> > > > Sean
> > > Sorry, meant to say that I've *never* used the PHP mapscript and
> > > don't understand the use for saving and loading queries.
> > > Sean
> > Hey, thanks for the reply.
> > Am I the only one using saveQuery? I think saveQuery and loadQuery
> > are terrific methods. They generate/read small files of
> shape index
> > values - similar, to a bitmap in Avenue I think. By
> loading a saved
> > query, I can return a layer to a previous query 'state',
> for lack of a
> > better word (resultCacheObj state?). This is extremely useful.
> > Building shapefiles does not allow for dynamic queries
> using AND, OR,
> > or XOR with previous queries, and it's too slow. The layer index
> > problem is easily handled by changing the layer index value in the
> > saved query file itself prior to loading. As long as only
> one layer
> > is queried at a time, this works well.
> > I'm trying to re-write an application using Python and without this
> > functionality it's a no go. I can't even emulate a
> saveQuery because
> > there is no queryByIndex method, and even if there was, stepping
> > through a list of indexes and calling queryByIndex is MUCH
> slower than
> > the loadQuery method.
> > I'm at a loss.
> > Adam
Umberto,
I thought about this too but running a query every time is too slow. And,
the only way to do succesive refining queries is to run multiple queries in
every session, and that's WAY to slow.
Adam
