Mapserver & Mapinfo files --HELP {Scanned}
Siki Zoltan
siki at AGT.BME.HU
Thu Sep 30 18:05:20 EDT 2004
I was not able to display MApInfo TABs with STYLEITEM AUTO.
I've read in the map file documentation "This is *very* experimental".
Try to remove STYLEITEM and add some style to your class e.g.
CLASS
OUTLINECOLOR 0 0 0
END
Bye
Zoltan
On Thu, 30 Sep 2004, Matthew crowley wrote:
> I'm sure there is something very simple that I am not understanding. Before
> trying to get all this working on my linux server, I thought I would try the
> MS4W package from DM solutions to get the hang of things.
> I have spent two days trying to get a MAPINFO .tab file to display using the
> tutorial in MapLab.
> Basically, I just wanted to add another layer using my own source file. OGR
> works, and I don't get any errors when I use the Preview function. My layer
> appears in the menu, but I can't see anything displayed on the screen
> The extra lines from my MAP file are :
> LAYER
> NAME "MBBDY"
> STATUS ON
> TYPE POLYGON
> CONNECTIONTYPE OGR
> CONNECTION "c:\ms4w\apps\maplab-2.2\tutorial\data\MBBDY.tab"
> STYLEITEM "AUTO"
> CLASS
> END
> END
> and the output from OGRINFO follows:
> C:\ms4w\tools\ogr-utils>ogrinfo -ro -al
> INFO: Open of `c:\ms4w\apps\maplab-2.2\tutorial\data\MBBDY.tab'
> using driver `MapInfo File' successful.
> Layer name: MBBDY
> Geometry: Polygon
> Feature Count: 1
> Extent: (-102.001400, 48.996530) - (-88.989300, 60.000970)
> Layer SRS WKT:
> GEOGCS["unnamed",
> DATUM["MIF 0",
> SPHEROID["WGS 84 (MAPINFO Datum 0)",6378137.01,298.257223563],
> TOWGS84[0,0,0,0,0,0,0]],
> PRIMEM["Greenwich",0],
> UNIT["degree",0.0174532925199433]]
> Filename: String (10.0)
> OGRFeature(MBBDY):1
> Filename (String) = MANITOBA
> Style =
> BRUSH(fc:#60ff60,bc:#ffffff,id:"mapinfo-brush-2.ogr-brush-0");PEN(w:1px . .
> Is there a parameter missing from my MAP file?
